oil weights (Summer)
Old Jun 6, 2006 | 09:02 AM
barthelb's Avatar
barthelb
Master
I think its available in 10w50 and 20w50 for hotter climates. Not sure about 5w50, i believe im using Valvoline.
Originally Posted by HoldThisForMe
Not exactly sure myself. I'll look when I get back to the house
Old Jun 6, 2006 | 11:39 AM
RBALDINELLII's Avatar
RBALDINELLII
Castrol makes a 5w-50 full synthetic.
http://www.partsamerica.com/ProductL...gorycode=4019J
Motorcraft and Mobil 1 both make it as well. I'm sure there are others.
Old Jun 6, 2006 | 02:58 PM
G3.5T's Avatar
G3.5T
Mobile 1 makes a 15w 50. I may try that or a 10w 40, Redline. I think Shariff was running 15w 50 Mobile 1, maybe he will chime in.
Old Jun 6, 2006 | 06:07 PM
Weqster's Avatar
Weqster
Originally Posted by theking
Having a thick oil doesn't imply less lubrication at all. If you want to stand on your soap box make sure you didn't place it in quick sand. People in hot climates have their oils heat up much faster and the only time the weight really matters(ie could hurt your engine) is when it is dead cold. It's not about overheating the oil it's about having the most protection and a 20w-50 at full temp will outprotect a 5w-30 any day of the week. Actually a dyno(conventional) oil at 20w-50 will outdue most syth 5w-30's in long term radioactive wear tests. One of the guys that I ride with(motorcycles) that is all he does for diesel companies.
Im not going to argue.
thicker oil flows a higher pressure, and thinner oil flows a higher volumn. Choose an oil that meets the engineers requirements at various operating ranges, and u have the correct oil for ur application.
Coldstart to me is an important cycle. I coldstart my engine 3-4 times a day. For race only conditions i would defaintly look into different weights, but temps can be managed much more reliably though an oil cooler, while retaining engineers original flow and pressure requirements.
Oh, and this is IMO
Old Jun 6, 2006 | 06:48 PM
HoldThisForMe's Avatar
HoldThisForMe
it is Valvaline Ultramax 5w-50 that was put in my car
lapham3
Oct 7, 2022 03:15 PM
kyin
Oct 15, 2015 05:54 AM
Mattg350z
Oct 2, 2015 06:51 AM
