Turbo timer and problem with AC
Old Jun 5, 2006 | 06:48 AM
lucidazn's Avatar
lucidazn
Default Turbo timer and problem with AC
I just installed the Blitz DCIV TT installed. Now whenever I start the car, my AC comes on in full blast in automatic mode @ 75 degrees. Anyone know why?
Old Jun 5, 2006 | 06:50 AM
MIAPLAYA's Avatar
MIAPLAYA
$20 says you accidentally forgot to reconnect the harness for your AC controls...its right behind the panel. Its a white ribbon cable.
Old Jun 5, 2006 | 06:53 AM
lucidazn's Avatar
lucidazn
But I can still control the functions of the fan/ac and the modes.
Old Jun 5, 2006 | 06:59 AM
MIAPLAYA's Avatar
MIAPLAYA
Hmm guess I just loss my $20...check it anyways...
Old Jun 5, 2006 | 07:36 AM
lucidazn's Avatar
lucidazn
Behind which panel? Right underneath the fan control panel? If so, I didn't touch that area... Only worked underneath the steering column and the driver side fuse box.
Could it be possible that I used the power wire leading to the fan/ac controls? It was a red abiut 14 gauge wire underneath the steering column that I tapped into.
Old Jun 5, 2006 | 07:37 AM
MIAPLAYA's Avatar
MIAPLAYA
Its possible but unlikely......maybe a blown fuse of some sort....Theres a lot of wires down there and if you used the solid red wire that is larger then all the others it should have had no affect on the AC. Thats what I used...
Old Jun 5, 2006 | 10:13 AM
lucidazn's Avatar
lucidazn
If it was a blown fuse, it would just cease to work... so weirddd anyone else?
Old Jun 5, 2006 | 03:38 PM
azaz's Avatar
azaz
What are the temps inside and outside the car? Is the car directly in the sun?
If it is warmer than 75 degrees inside the car then the automatic temp control will control the temp blend door and the blower speed to get the inside temperature of the car to the temp setting on the dial. Especially if the car is heat soaked in the sun. Inside temperatures of the car can be 100 degrees or more depending on sun load and how long it has been sitting. So the car is just trying to cool itself down as quickly as possible. Mine does this and usually within a few minutes the blower will slow down.
Hope this helps,
Tony
Old Jun 5, 2006 | 04:09 PM
lucidazn's Avatar
lucidazn
Hope this helps,
Tony
Interesting.... I don't ever remember this happening though... I'll go turn my car on later at night where it's below 75 degrees.
Old Jun 5, 2006 | 05:49 PM
HoldThisForMe's Avatar
HoldThisForMe
is the a/c *** sitting in the auto position?
Old Jun 5, 2006 | 05:59 PM
lucidazn's Avatar
lucidazn
I have a G35, no ***** =/
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
