Why does it cost so much to go FI??
Old Jun 13, 2006 | 03:38 PM
sentry65's Avatar
sentry65
the burninator
I think everyone kinda wonders a bit about what if they went TT instead.
at the end of the day for the amount of power you're going to run anyway, is it REALLY worth the added cost? For some people that just gotta have that extra 500 rpm spool up, extra heat and extra weight it's worth the extra cost
Old Jun 13, 2006 | 05:06 PM
TENGAI's Avatar
TENGAI
Going TT is just plain expensive. Whether or not it's worth it is up to each individual, but coming from someone who's running twins... every minute behind the wheel is money well spent.
Old Jun 13, 2006 | 05:55 PM
dingobiatch's Avatar
dingobiatch
I'm a little confused on the whole A/C thing.. airconditiong gets messed up from turbo systems??
And I'm still confused, would I really need a bigger radiator, oil cooler, etc?
Is it unsafe to go with just the single turbo and gauges?
Old Jun 13, 2006 | 05:57 PM
Jokestrap's Avatar
Jokestrap
Guys, this could go on and on. The bottom line is you can take a fantastic car like the lines of the Z and add $$$ to get you to 60% of the cost of exotic cars that you can stomp on daily. What kind of rush is that.... Enough said, stop the madness. At roughly 550rwhp, there is relatively nothing on the street or track that can match the power and handling of a Z when done right at a fraction of the cost of cars that can't even hang. How insane is that. Like Nike, "Just do it"
Old Jun 13, 2006 | 08:49 PM
Bullitproof's Avatar
Bullitproof
I just got my car back from car version 2 tonight. took my aps st, added cams and utec. the before numbers were 385whp/402tq at 9psi. i got 420whp/412tq at 9.5psi with the new setup and 440whp with c-16. i'm very happy with the setup but i did pay more to get the same whp as a tt. but for me its about the journey. i've probably spent enough money, including the price of the car, to buy a z06, but i would have had to wait two years to get it. and that would have sucked. i'm a car guy and its not about buying the fastest car out there, it's about personalization for me. if i bought a z06 for example, i would still want rims, tires, exhaust, etc. so for me the z/g platform was the best choice for me. will i get tired of the horsepower and want to build the motor eventually? heck yes!!!!!!!! it's like a sickness you know?
Old Jun 14, 2006 | 08:27 AM
beastie's Avatar
beastie
Did you get your engine built or just cam work? Anyways nice #s!
Old Jun 14, 2006 | 08:31 AM
barthelb's Avatar
barthelb
Master
my opinion is if your having problems justifying or affording the setup initially, don't do it. Cuz if something goes wrong and it breaks. Your gonna be hurting to get it fixed. I've seen that happen many times. If you can't fix it if it breaks don't do it, period. Other than that it will be expensive.
Old Jun 14, 2006 | 09:19 AM
MIAPLAYA's Avatar
MIAPLAYA
Originally Posted by josh846
a turbonetics kit is 5100, guages boost, egt 550, then to install that you will need around 1500 including the guages installed. You will have to have your a/c recharged which is 130-150. Your factory a/c is going to get the high and more than likely the low side burned, no matter what someone tells you, it will the exhaust side of turbo is poorely designed in that it is way to close to both lines and burned through both of mine, and yes we did everything that the instructions say to do, and we could not get the lines away from the exhaust piping. that ended up costing me 950 to get custom ran high and low lines. they had to uninstall the top part of the turbo and alot of labor involved in designing it, i could have done it myself but did not have the time. that is the least you will need, but then i would say get a utec or some kind of engine management, which will be around 500 low end and 2000 high end. then to get it tuned probably close to 700 with just one map, that is about the least amount of stuff you will have to do. I am not sure if i had to do it over again i would go with the tn kit, but it does get good power, i might spend a few extra dollars and get a complete kit with ecu that will not burn my ac lines, becuase that a/c line problem only cost $950 money wise but more more than that in my time having to deal with it running it to different places and letting them do it very disheartening actually that it was designed so poorly in that aspect. I think TN should reroute the a/c line and make it part of the kit, even though it will raise the price another 200 who cares i wouldn't mind paying another 200 when already paying 5100.
Thats interesting. I have 50k miles on my car. 30k with the Turbonetics kit. Never had a single AC issue. Not one. I know of PLENTY of other members who can say the same. And the kit does come with one re-routed AC line which when installed properlly should be all you need.
Old Jun 14, 2006 | 02:35 PM
Jokestrap's Avatar
Jokestrap
I do agree w/this...
Old Jun 14, 2006 | 03:12 PM
Bullitproof
thanks beastie, just cams and utec. built motor will probably be winter 07.
Old Jun 14, 2006 | 03:37 PM
Speedracer's Avatar
Speedracer
Originally Posted by dingobiatch
I might get flamed, I've searched but I can't find a simple answer to this question.
I was just looking at the Greddy Twin Turbo kit, which I've seen going for $5.6k or so. People on the forums talk about how they spend upwards of 15k-25k on their cars to go FI, and I don't think that included an engine build.
So, my question is, why does it cost so much more over the kit price? I know install is a grand or so, but still. And tuning probably costs a bit. But what else goes into those massive amounts of money spent on FI?
And I'm talking about only going to 360whp or so (which is said to be what the Greddy TT kit will do at stock boost).
It's not just the engine. It's bringing all the components of the car up to a level to balance and cope with the power of the engine.
wheels + tires = $3000-$4000
Full brake kit = $5000
Full suspension = $2000
Clutch = $1500
Exhaust = $1000-$2000
Plus.....rear diff, oil cooler, gauges, etc
Plus labor costs........get the idea?
Old Jun 14, 2006 | 03:45 PM
josh846's Avatar
josh846
Well the 3 people i know of here in town all have the same problem with the AC line. I have seen many threads about the issue on here or other sites. that is one thing i had heard was the main problem with the TN kit, but when i talked to the guy before i ordered it he assured me that the issue had been fixed, which it hadn't and the reroute is really to long and the way you have to install it it brushes into my exhaust pipe that burned the hole in it. i had to get another 3 inches added to it and then went around my sway bar, probably not the best idea, but better than being up against the exhaust. Also why hasn't TN fixed the problem with their wastegate, telling you to install it backwards? my shop did since it was their first install, luckily they caught it when checking the a/f ratio, and yes i do have gauges, but it boosted up to around 28 on the dyno, which could have very easily blown my engine.
Old Jun 14, 2006 | 07:54 PM
MIAPLAYA's Avatar
MIAPLAYA
Again another issue with people improperly installing hardware. If you read the instructions and look at the orientation of the wastegate its pretty easy to understnad. I suppose it would be possile to confuse which one is the BOTTOM wastegate port because its upside down on the pipe but if you think about where the logo is in relation to the ports its easy to understand the port furthest from the logo is the bottom one. Several members here were able to install this kit on jack stands and get that right..
Old Jun 14, 2006 | 08:21 PM
jlimquest's Avatar
jlimquest
Funny, I just answered this in the other forum. So here it is. Hope it helps. No issues here w/ the TN.
1. Brand of Turbo would you rec? TURBONETICS ST
2. Cost$$$ parts $5300 (5AT version w/ CAT)
3. Cost$$$ labor $1700 (Includes Turbo, plenum spacer install, DC header removal, 3 gauges w/ pillar, Reverse Y pipe fabrication & Dyno http://www.danzioperformance.com/default.asp Regular TN turbo install only = approx. $1300
4. Time factor-How long? 1 week
5. Does adding a turbo charge decrease the number of years on the ride? Depends on proper install & tune
6. Is turbo ok for a daily driver? Yes
7. Do I have to change out anything else? W/ TN none Exhaust? optional Headers? No, fitting issue, just JetHot coat Etc? Gauges EGT, Boost & AF wideband = $500, 5/16 Motordyne plenum spacer = $200
Im also located in the Pasadena area if you know of any decent shops. DANZIO is SO CAL (El Sinore) recommended by TN
8. Last question: Is it worth it? YES, for less than $8K (TOTAL parts & labor) BEST BANG FOR BUCK DAILY DRIVER TURBO set up!!!
Attached Thumbnails Why does it cost so much to go FI??-dscn1391-medium-.jpg   Why does it cost so much to go FI??-rscn1524-medium-.jpg   Why does it cost so much to go FI??-rscn15141-medium-.jpg
Old Jun 15, 2006 | 08:20 PM
redman333's Avatar
redman333
I definetly agree with barthelb on this one. I had a TN installed on my car and the same day blew the motor. I still don't have my car back. It's been about 2 1/2 weeks now and after I get the new engine in I'm spending another 5k on another shop to put the kit in properly and have it tuned which will take another week. So the grand total on down time will be 3 1/2 weeks and $11k. So think about it carefully. I really can't afford to have my car go down, but still want the turbo, so I'm just spending more on making it reliable.
Old Jun 15, 2006 | 09:49 PM
woodstock300s's Avatar
woodstock300s
^how many psi were you runnin?
Old Nov 21, 2006 | 04:30 PM
redman333's Avatar
redman333
8.5psi, but it spike, don't know how high though. Since then I've had a new motor put in and TN kit and had alot of other supporting mods done to it.
Oil cooler necessary? Depends, I didn't have an issue until I decided to take my car to the track, I ran for about a half hour and had to stop, the oil was way to hot. On my kit I installed the utec to better handle the stock ecu. I make a conservative 365whp and 360tq. Running about 8.5psi still but it does spike to almost 11 every once in awhile, good thing I have a good tune.
Old Nov 21, 2006 | 04:56 PM
  #38
rocks's Avatar
rocks
I say for 20k$ you can have a built engine and turbo kit all installed and tuned and make close to 500hp on a daily driver. My engine should be done with in 2 weeks. Fully built with jwt cams, no sleeves though. Built Z Motors is building my engine, if i did all the work myself i would of maybe saved 1000$, but my car came back in peices from the dealer, and if i dont take something apart i usually get somewhat confused on how it goes back together.
Next i need to buy a limited slip, going to get a stock one out of a junkyard for like 300-400$. Return fuel system around 1000$, utec is 600-1200$ hopefully i find a used one. I may find a used aps single turbo kit and modify it, i could sell the turbo and pay around 2000$ for the kit looking for used crap. Of course if you can do all the work yourself its way cheaper. If you have to pay someone you better have a savings account and put like 500$ a month in it. I can work on cars not having a warranty will not bother me.
Old Nov 22, 2006 | 09:03 PM
  #39
overZealous1's Avatar
overZealous1
the cost is pretty much right on par with many other cars when going for a level of 700+ crank hp. parts are expensive for the Z though, mostly the reason being that people building these cars have a few extra bucks and want the best for their investment. you will not find many "cheaply" made parts for this car for f/i.
Old Nov 22, 2006 | 09:25 PM
  #40
mraturbo's Avatar
mraturbo
All true...
And nothing beats a Perfect 500 WHP/500 Torque with a perfectly executed car including brakes, suspension, cooling, rear end, rims/tires, and more.
Note:
Tanner Faust recently raced my Yellow Z in a Time Attack and said,
"This is definitely not a race car" with its full interior - AEM cut his Drift Car apart to drop about 400 lbs. Beside, in my car I don't want to ditch the 1000 watts stereo with Mac Amp. Although he continued to state -
"This is the fastest and most complete street car I have ever driven." His daily is a new M3 that cost him $70k so I take that compliment very highly. Tanner is a Pro Rally and Drift Racer and he knows his stuff.
Be Proud - We are working with a wonderful platform with the Z and Gs so enjoy. And yes it cost allot to have the sh$t.
M
