Seperate Oil for turbos
Old Jun 9, 2006 | 08:10 AM
jeff0181's Avatar
jeff0181
Default Seperate Oil for turbos
I'm sure people have thought of this before, but wouldn't a seperate oil supply systme for the turbochargers keep the turbos cleaner and give them a longer life span. If you had two oil pans, a larger one and a smaller one for the turbos then none of the dirty oil that is used in combustion would touch the turbos, thus keeping them cleaner, giving them a longer life span, and you would probably not have to change the oil as often. It's probably not worht it for the extra weight and equipment but just an idea.
Old Jun 9, 2006 | 08:16 AM
gringott's Avatar
gringott
I agree, and am also wondering. I know that someone posted here a year ago or so about a custom TT kit with sep. oil system.
Old Jun 9, 2006 | 08:29 AM
350Zteve's Avatar
350Zteve
This would present a bunch of challeneges. You would first need a separate tank for the oil. Then you would have to run an electric oilpump and plumb in a filter. If the electric pump failed, your turbos would be toast. Lastly, where the hell would all this stuff go? There's so little room already in the engine bay.
Old Jun 9, 2006 | 11:00 AM
bailey bill's Avatar
bailey bill
That's a solution to a problem that doesn't exist.
Change your oil and filter on a regualr basis, consistantly allow a cool-down cycle, and you should have no problem getting 250K from any good quality turbo.
If it ain't broke, don't fix it.
bill
apex locator
Jul 23, 2021 02:27 AM
