Weird Noise coming from the Turbo???
Old Jun 15, 2006 | 08:29 AM
VashZ350's Avatar
VashZ350
Default Weird Noise coming from the Turbo???
When I shift down with AT-TipTronic to slow down, its sounds l like the turbo rattles (like when you drive a bicycle and stick a "pokercard" between the spokes)
I hope someone knows what I mean .. cuz Its hard to explain
Old Jun 15, 2006 | 08:31 AM
MIAPLAYA's Avatar
MIAPLAYA
Could be piping rattling against the body of the car...
Old Jun 15, 2006 | 08:33 AM
VashZ350's Avatar
VashZ350
hmm maybe I could upload a soundfile... I'll check my piping and try it again..
Its just sounds like that when I shift down like lets say @ 5000-3500 rpm's ... @ 3000-2000 rpm it doesnt rattle
Old Jun 15, 2006 | 11:12 AM
-EL's Avatar
-EL
Do you have a blow-off valve? Is it opening? The turbo compressor vanes can make a fluttering sound (compressor surge) if you have pressure building up inside your intake. Just a WAG.
Old Jun 15, 2006 | 03:12 PM
VashZ350's Avatar
VashZ350
yeah I got a blow-off valve and its open... I know the fluttering sound is normal .. .but not a rattle sound if down_shifting (no gas is pushed) (like when you drive a bicycle and stick a "pokercard" between the spokes)
like miaplaya said... it sounds like some piping or maybe the turbo itself is rattling against the body of the car...?
(just a thought)
Oil should be fine... I check my oil and it was right in the middle of low and high
Old Jun 16, 2006 | 04:30 AM
VashZ350's Avatar
VashZ350
okay found out the problem..... the piping underneath the turbo has a hole ! The vibration of the turbo was hitting the pipe and kinda killed it..
Possible to solder or do I need a new pipe?
Old Jun 16, 2006 | 04:54 AM
rabbid's Avatar
rabbid
HELIARC it!!!!
Old Jun 16, 2006 | 06:14 AM
MIAPLAYA's Avatar
MIAPLAYA
If it is a Turbonetics pipe just let Reggie know which one it is and he will send you a replacement. It would be easier if you tell him the exact part number of the pipe. Pics and part numbers are in the install guide. I just happen to have a copy of it on www.turboneticsownersclub.com http://turboneticsownersclub.com/tur...icsinstman.pdf
Old Jun 16, 2006 | 06:20 AM
plumpzz's Avatar
plumpzz
^ customer service A+
Obadabot
Jun 18, 2023 11:31 PM
Uriyo_
Sep 8, 2021 08:46 AM
samansharif
Sep 25, 2015 12:31 PM
