head lift, then this
Old Jun 22, 2006 | 10:32 PM
RTracing's Avatar
RTracing
Default head lift, then this
I was having problems with the heads lifting then finaly this happened. What should i do. just get it fixed or get new darton sleevs?
Old Jun 22, 2006 | 11:24 PM
rookie's Avatar
rookie
Ouch, what did the gasket look like? I thought you parted it out?
Old Jun 22, 2006 | 11:53 PM
plumpzz's Avatar
plumpzz
change ur pistons! with the money you spenton your car, such a high cr is gonna be bad for you!
PS, i thought u sold ur car?
Old Jun 23, 2006 | 12:13 AM
RTracing's Avatar
RTracing
I sold the turbo's, i thought i just blew the headgasket, but then i found this when i took the heads off. I am keeping it NA to stay out of trouble. I am actualy going with 11.1 compression, and keeping the car.
Old Jun 23, 2006 | 12:17 AM
RTracing's Avatar
RTracing
On this one my spark plug broke and screwed the piston up.
Old Jun 23, 2006 | 02:35 AM
aalzuhair's Avatar
aalzuhair
WOW .... the sleeve cracked .. WOW
What do you have on the engine? How much PSI were you running?
Old Jun 23, 2006 | 02:39 AM
mistaboosta's Avatar
mistaboosta
is there any damage on the head where the sleeve is cracked? it can be because of the inproper torque specs of head bolts.
Old Jun 23, 2006 | 05:25 AM
booger's Avatar
booger
Was this the drivers side ? My gasket failed on all three driver side pistons on the intake side .
Old Jun 23, 2006 | 09:57 AM
RTracing's Avatar
RTracing
Yes it was the driver's side, the head has no damage. I was running 14psi on 10.5:1 forged pistons. making over 600rwhp.
Old Jun 23, 2006 | 10:34 AM
-EL's Avatar
-EL
Is it just me, or does that look like it burned/melted through, rather than cracked? Anyway, I'm guessing that can't be fixed by redecking, so I vote for Darton sleeves, especially given the power you were making.
-E
Old Jun 23, 2006 | 01:34 PM
overZealous1's Avatar
overZealous1
there is actually a chunk o the cylinder gone!!! i must say, that is a very weird thing to happen. your cylinder pressures had to of been through the roof!!
Pleask
Dec 21, 2021 03:17 PM
AbrasiveRaysive
Sep 20, 2021 02:29 PM
350Z_Al
Oct 29, 2020 07:44 PM
