Keep up with 0-60 times of a 911, Z06, Stealth, or GTR
Old Jun 26, 2006 | 08:17 PM
mrtomcat's Avatar
mrtomcat
yep I got on
Old Jun 26, 2006 | 08:24 PM
AmyCroft's Avatar
AmyCroft
Smile Must be my Java out of date
Originally Posted by mrtomcat
yep I got on
This old computer in the Garage is Win98. I'll sign-on the new HP in the Sports room and apply.
If my wife will let me..
Cheers Amy -
Old Jun 27, 2006 | 06:24 AM
mraturbo's Avatar
mraturbo
Originally Posted by t32gzz
The biggest problem on a built FI'd Z is the 0 part of the 0-60. With our stock FD your biggest problem will be traction. To have a 3.8 0-6 you must hook up relatively well and you would do better with less boost than more. From 0-100 a built Z will blow all of them away. Even 30 -60.
To get good 0-60 times spend good money on tires, camber of your rear tires, springs that are soft enough to allow a weight transfer to the rear tires and a TT kit running around 9psi. You will be at 3.8 easily with the right suspension.
Well said
IMO, the car that is bone stock AND is the greatest beast of them all WITH CARB and a WARRANTY is a new Z06.
As for a launch from a stand still and Zero to 60, no matter what we used to put head to head against my older Z06, it still ran 3.9-4.0 with street tires and without drag radials with only 12 PSI, good luck beating those times. As for beating the New Z06 0-60 or 1/4 miles, goodluck. 50 years of Corvette racing and dragstrip gives them an amazing advantage from the launch...Suspension design and gearing play the biggest roles here.
M
Obadabot
Jun 18, 2023 11:31 PM
SharX59
Sep 27, 2015 09:23 AM
