Knock detector?
Old Jun 25, 2006 | 12:56 PM
chris'smax's Avatar
chris'smax
Default Knock detector?
I am looking for a knock meter w/ a display that i can use to help tune w/. I have emanage blue w/ the timming harness to adjust the timming, but i need a dsplay that will display a accurate knock count. I will be using this on my vortech S/C setup.
Old Jun 25, 2006 | 12:58 PM
VenomZ's Avatar
VenomZ
check out the R-500 from PLX Devices
Old Jun 25, 2006 | 01:52 PM
chris'smax's Avatar
chris'smax
thanks for the reply, but i already have a zeitronix wb o2. I am looking for a independent knock detector.
Old Jun 25, 2006 | 02:01 PM
booger's Avatar
booger
You can hook up the user input on the Zeitronix to the stock knock sensor and log volts coming from the sensor . Several guys are doing this and it seems to work pretty well . When I was street tuning my car . At one time , between 6000 and 6500rpm I saw spikes in the volts [ over 3 ] normal volts are 2.53 , or close . I retarded the timing a little more and never seen that spike again
Old Jun 25, 2006 | 02:04 PM
chris'smax's Avatar
chris'smax
I thought about doing that, but do you know where i can find the voltage ranges for the knock sensor? I would guess that when you were tunning it on the lap top you just reduced ignition timming till you saw a flat voltage line on the laptop?
Old Jun 25, 2006 | 02:09 PM
booger's Avatar
booger
Like I said . Normal volts are around 2.53 . You see a flat line when datalogging . I see very small increases once in a while [ .03 in volts to 2.56..2.58 ] But any thing over that I consider knock .
Old Jun 25, 2006 | 02:25 PM
chris'smax's Avatar
chris'smax
gotcha. Just wanted to make sure i had a clear understanding.
pinkie
Sep 16, 2022 09:55 AM
Brantwilliams13
Sep 16, 2015 05:03 AM
Inspatatrac
Sep 8, 2015 02:12 PM
droideka
Dec 7, 2002 03:41 PM
TXSTYLE
Sep 13, 2002 08:25 AM
