No Throttle
Old Jul 1, 2006 | 11:59 AM
BobaFettm's Avatar
BobaFettm
Default No Throttle
So... the Z has no throttle control at all... The shop thought it was the UTEC cuz it happened before to it... with the same thing but now I got the AEM in there and its still doing it
Even when we just plug the stock ECU into the car it still wont see a throttle control at all... just turns on and nothing from the gas pedal!
Anyone heard of this before?
TF has been talking to Technosquare and they both believe it could be the stock ECU (Technosquared reflashed) itself...
Old Jul 1, 2006 | 12:17 PM
rookie's Avatar
rookie
Could it be the immobilizer? I was working with TS on a new ecu and we attempted a different year program minus the immobilizer, the engine started but no throttle control.
Old Jul 1, 2006 | 03:52 PM
BobaFettm's Avatar
BobaFettm
ill shoot them that comment and see what they say!
Old Jul 1, 2006 | 03:58 PM
rookie's Avatar
rookie
Do this put it into the on position, if the alarm light on the dash is lit than the immobilizer may be the cause. Hope it gets resolved.
Old Jul 2, 2006 | 07:07 AM
BobaFettm's Avatar
BobaFettm
k ill check with them... but they seem to think its something else still
Old Jul 4, 2006 | 06:30 AM
BobaFettm's Avatar
BobaFettm
Any other ideas guys? I havent been able to really get my car back since feb. Would be great to finish this up and get it home...
Old Jul 5, 2006 | 06:24 AM
BobaFettm's Avatar
BobaFettm
Bump for a broken car all summer...
Old Jul 5, 2006 | 06:34 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Can you drive the car for a few minutes then it stalls and you get no throttle control? Or is the car just starting and then you can hit the gas all you want and you get little to no revs? I had the same thing happen to me after Turbonetics flashed my ECU for the turbo kit, I thought it was a flash gone wrong. Turns out it was a bad coincedence and my throttle body went bad! I have an 03' supposedly the inside gears are metal and seize over time. 04's and up have some hard plastic gears designed not to seize up, I bought a used TB for around $100 and all is well now. Also if you turn the key to the "ON" position, you can hear your TB opening, on mine the normal sound turned into a horrible sound. Good luck, keep us posted.
Edit-just noticed you have an 05' Id still look into it...
Old Jul 5, 2006 | 07:24 AM
BobaFettm's Avatar
BobaFettm
Same problem! I press the gas and get nothing right after I start the car...
so maybe mine did the same thing as yours! Right after the TS reflash my cars TB just died randomly
Old Jul 5, 2006 | 07:39 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Yeah just a bad coincidence I dont blame TS's flash. Try www.car-parts.com for a 04' and up TB. You can always talk them down when you call. Keep us posted...
Old Jul 5, 2006 | 07:42 AM
taurran's Avatar
taurran
Did you plug in the throttle body?
Old Jul 5, 2006 | 09:44 AM
BobaFettm's Avatar
BobaFettm
im not the one doing the work... the shop is...
they told me "the tb wont open under load"
so its slightly different then yours Alberto
Old Jul 6, 2006 | 04:11 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Mine wouldnt open under load either, just enough to keep it idling...
Old Jul 6, 2006 | 06:09 AM
BobaFettm's Avatar
BobaFettm
ah then yup same thing...
im guessing its exactly your problem... but my shop thinks otherwise
Old Jul 6, 2006 | 06:39 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Screw your shop if they havent done anything for you yet to solve this-you rnot getting a CEL? Track down a TB and try it, worst comes to worst it doesnt work you can sell it, or send it out to get bored....
Old Jul 6, 2006 | 08:06 AM
BobaFettm's Avatar
BobaFettm
As of right now they said they have a machine coming from Technosquare to test the ECU
Old Jul 6, 2006 | 08:54 AM
BrianLG35C's Avatar
BrianLG35C
Is this shop TF?
Old Jul 6, 2006 | 08:58 AM
BobaFettm's Avatar
BobaFettm
yes Tuning factory has been doing all my work since Febuary (TT install, built motor and stuff)
Old Jul 6, 2006 | 09:37 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Any CEL's?
Old Jul 6, 2006 | 12:20 PM
Yancy's Avatar
Yancy
I feel you bro.
