Who has the highest revving motor? Dynos? power past 6600rpm?
Old Jul 6, 2006 | 02:08 PM
  #41
bigbri's Avatar
bigbri
Originally Posted by failsafe306
Ooh-Ooh!! What is the prize if we guess it!
I'll guess 673 @ 7500 rpm
The prize is a fatass naked bit ch on your doorstep...you guys like big biatchs right??
Old Jul 6, 2006 | 02:52 PM
  #42
o snap its eric's Avatar
o snap its eric
im just hoping the dyno numbers on the dastek are the same as the dynojet =)
PS: Can i just get a naked ***** on my doorstep even if i guessed wrong bri?
Old Jul 6, 2006 | 03:09 PM
  #43
bigbri's Avatar
bigbri
So you like fat *****s??
Old Jul 6, 2006 | 03:17 PM
  #44
o snap its eric
i like them jiggly!
Old Jul 6, 2006 | 06:54 PM
  #45
Alberto's Avatar
Alberto
Cranky FI Owner
684 @ 6500rpms <----my guess
Old Jul 6, 2006 | 07:04 PM
  #46
bigbri's Avatar
bigbri
Damn I hope thats not the case...That would suck if I was reving to 8000rpms and not making any power above 6500rpms....I guess when I shifted I'd be at my peak power if that were the case......
Old Jul 6, 2006 | 07:48 PM
  #47
failsafe306's Avatar
failsafe306
Don't tease me Bri
Old Jul 6, 2006 | 09:26 PM
  #48
bigbri's Avatar
bigbri
Don't tease me Bri
LOL Biggest BIATCH you've ever seen....
Old Jul 7, 2006 | 01:53 PM
  #49
t32gzz's Avatar
t32gzz
Put me down for 713whp @ 6700 rpms w/ 23psi. I will be surprised if the peak poer is much above that.
Old Jul 7, 2006 | 01:56 PM
  #50
t32gzz's Avatar
t32gzz
Put me down for 713whp @ 6700 rpms w/ 23psi. I will be surprised if the peak power is much above 6700 rpms. Either way, I know your ride is fast, but very interested in where the peak power is.
Old Jul 8, 2006 | 11:31 PM
  #51
overZealous1's Avatar
overZealous1
i still have the stock rev limit set in my car. the dyno was still at a very steady climb at that point. it surely will make power well above 6600. i have removed mucho metal from the intake and heads though and running nismo cams too. will get another dyno soon as my clutch was slipping hardcore last time. putting in a custom tilton triple disk with weight added to the flywheel to make it street friendly. can't wait!!
Old Jul 9, 2006 | 01:17 AM
  #52
Trav4011's Avatar
Trav4011
We'll be revving out our VQ project to 8500rpm. I have disabled/removed the CVTC system (VQ30 timing covers, gears, chain and water pump). We have some pretty large cams, and valve springs to provide enough seat pressure to keep valve float out of the picture. This will be in a FWD car, running through a Maxima 6spd. GT42R, 1000cc injectors, and Electromotive management.. The engine is sleeved/built, and has some L19 studs/cometic gaskets. So, we'll see just what the VQ will hold.. I've got enough injector/turbo for around 900whp.. On paper, the cams/springs should let us go to 8500rpm without float. The intake manifold has a plenum volume of about 5.5 liters, with 11.7" total runner length. Peak power should come at about 8000-8200rpm with this combination.. We'll see, soon..
Travis
Old Jul 9, 2006 | 08:53 AM
  #53
350zDCalb's Avatar
350zDCalb
builtZmotors
looking through some of my old dyno charts, in this one, i made power until we let off at 7000rpm, it leveled off from 6500 up ,but hp didnt drop...hmmm
-come on guys, get the charts up, I want to see what your power curves are doing!
-TODD
Old Jul 9, 2006 | 10:08 AM
  #54
bigbri's Avatar
bigbri
Travis
Damn thats a beast....
Old Jul 9, 2006 | 10:09 AM
  #55
bigbri's Avatar
bigbri
-TODD
See man it can be done now you contradicting yourself...you started this thread saying power can be made past 6600...
Old Jul 9, 2006 | 12:47 PM
  #56
350zDCalb's Avatar
350zDCalb
builtZmotors
i know!!!! i found this dyno graph and felt like an idiot...this is on stock cams...
hahaha
Old Jul 9, 2006 | 01:38 PM
  #57
helldorado's Avatar
helldorado
This raises an interesting question in the interpretation of power. Do you consider the measure of power to be your horsepower or torque readings?
Personally, I look at the torque curve for power so from that perspective, you're gradually losing power from 4700 rpm on. Because of the nature of the HP - Tq calculation, you can lose torque and still maintain or even build HP. Granted you're still making 460 ft-lbs at 6900 rpm but thats about 120 ft-lbs less than the 580 ft-lbs you're making at 4700 rpm, and the car won't pull quite as hard.
Not meant to flame or anything, but I feel that interpretation of the numbers really changes the nature of the discussion and I think this is a very worthwhile topic.
Old Jul 11, 2006 | 11:57 AM
  #58
barthelb's Avatar
barthelb
Master
Im gonna guess 580-620whp @ 7200rpms
Old Jul 11, 2006 | 03:23 PM
  #59
bigbri's Avatar
bigbri
Thats it??? I hope that's not the case or there is going to be hell to pay....
Old Jul 11, 2006 | 04:14 PM
  #60
D350Z10's Avatar
D350Z10
I believe it is gonna be at 710@7500 rpms, i just talked to TED about those cams, and from what he told me he will make power all the way through. So off course I had to buy a SET!!!!
