TT vs ST dyno overlay
Old Dec 4, 2006 | 09:55 AM
  #121
03BrickyardZ's Avatar
03BrickyardZ
Originally Posted by BriGuyMax
Actually I was talking about the exhaust stroke. When the rod is at an angle the piston is not changing direction. The direction change is what puts the most stress on the rod and it only happens at the top of the stroke or the bottom of the stroke when the rod is exactly perpendicular to the force being applied.
the most stress on a rod is going to be created at any moment that the force down on the piston (and up on the crank) is at a maximum, which would be during combustion.
You are correct in that if a constant force is applied to the piston (with counterforce at the crank) then the most stress is when the rod is perpendicular to the piston, because at all other positions, some of that force is being opposed by the sidewall of the cylinder.
However, the force on the piston during combustion is many times what it is during any other point in the cycle, which overwhelms the reduction in stress to to the angle of the connection rod.
This is however, moot. The most stress on a rod would be in a binding situation (oil starved or turned journal), which creates a shear component to the stress, which will, in technical terms, f*** yo rods up, man.
Old Dec 4, 2006 | 10:49 AM
  #122
tig488's Avatar
tig488
Originally Posted by captj3
The st may make more tq than hp, but the tt are more linear in there tq. They carry the tq to redline where the st's drop off like a brick.
not necessarily, a lot ot twin setups drop tq too, just look at the dyno above your post.
Old Dec 4, 2006 | 11:10 AM
  #123
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Exactly, but my point was that it's not "power" that typically breaks rods. Excessive RPM and oil starvation are much more common factors in rod failure. Taurran claimed that that ST turbo setups are more likely to break rods because they produce more peak torque. I disagreed and I don't see how anything you have said counters what I said.
Old Dec 4, 2006 | 11:29 AM
  #124
03BrickyardZ
Fair enough... I misunderstood. I don't get to excersize my brain enough.
Old Dec 4, 2006 | 11:33 AM
  #125
Nismo 350z's Avatar
Nismo 350z
Originally Posted by 35ounces
???????? Did someone swap a TT for an ST?
No but Alberto did swap his ST to a TT.
Old Dec 4, 2006 | 11:54 AM
  #126
wtf no turbo's Avatar
wtf no turbo
Originally Posted by taurran
Yes, but not entirely. Show me a TT making 20-30ft lbs more than whp (that wasnt dynod at VRT).
Ask and you receive
Attached Thumbnails TT vs ST dyno overlay-dave_s_jwt_700r_350z___15psi_pump.jpg
silverbullet_Z
NA Builds
24
Nov 14, 2015 02:52 AM
seagrasser
Oct 11, 2015 03:27 PM
NissanZcrazy
Sep 23, 2015 07:59 AM
