Need Help! Only boosting to 2 psi
Old Jul 20, 2006 | 11:39 PM
mrtomcat's Avatar
mrtomcat
Default Need Help! Only boosting to 2 psi
went to the track tonight and during my last run I had no power. I took it on the freeway afterwards and saw that I'm only boosting up to 2 psi.
I had the same problem a few months back and a coupler from a pipe had come loose.
I checked (from what is visible from the outside) and all pipes seem to be tightly connected.
I'm fairly certain that it's a loose coupler that I can't see right now but could it be anything else?
car drives great otherwise.
Old Jul 21, 2006 | 12:24 AM
MI 35th's Avatar
MI 35th
OGPremierMafia
remove all the couplers check for rips or tears... not noticeable when still but will spread wide open under boost!
that plagued my mr2 until i replaced all of the connectors!
Old Jul 21, 2006 | 07:09 AM
Zues350ztt's Avatar
Zues350ztt
I had same problem and it was the coupler right next to the manifold it burned a hole in it.
Old Jul 21, 2006 | 09:39 AM
mrtomcat's Avatar
mrtomcat
with the heat here lately I wouldn't be surprised if that would be the case
Is there a way to test for this without having to take everything apart?
Old Jul 21, 2006 | 09:42 AM
MI 35th's Avatar
MI 35th
OGPremierMafia
yes soapy water, and looking for bubbles! not sure how easy itll be with the z but thats how i figured it out!
or you could make a boost leak tester!
pvc, air tool end, seal it all up and presurize the system!
Old Jul 21, 2006 | 12:35 PM
Nismo350ZRT's Avatar
Nismo350ZRT
Check your boost solenoid. It could be stuck open.
Old Jul 21, 2006 | 12:51 PM
mrtomcat's Avatar
mrtomcat
Is the boost solenoid mounted next to the BOV? (I have the APS TT)
Old Jul 21, 2006 | 01:33 PM
baptist's Avatar
baptist
Yes it is.
Old Jul 21, 2006 | 08:10 PM
mrtomcat's Avatar
mrtomcat
ok, quick update:
when I drove home from work I took my little canyon and noticed that everytime I make a sharp right turn the car makes a loud rubbing noise, it sounds like something is hitting the fan. When I straighten the car out it's fine again.
WHen I got home I checked for anything loose or close to the fans that might rub but nothing.
I then moved the wheel as if I'm making a sharp right turn but still nothing visibly rubbing.
Here's the interesting thing: I noticed oil under the right front bumper. I removed the inner fender lining and there is a small pool of oil right underneath the windshield reservoir. The only coupling that I can not see is the tube going into the intercooler, I'm kinda hoping that this is the loose one and the oil is build up since I don't have a catch can...
does that make sense?
Anyone know where oil could come from in that area?
I checked and there is nothing coming from the engine or oil pan so I don't think it's the engine.
I'm bringing the car to Brainstorm tomorrow. I hope they can fix this and it's nothing bad.
any thoughts?
Old Jul 22, 2006 | 04:50 PM
mrtomcat's Avatar
mrtomcat
I was right the coupler on the passenger side going into the intercooler came off. Brainstorm put a longer coupler on and all is fixed. YEAH!
I seriously need an oil catch can though
apex locator
Jul 23, 2021 02:27 AM
kyin
Oct 15, 2015 05:54 AM
codek
Sep 28, 2015 03:03 AM
