I understand the p300 codes the TN throws, but....
Old Jul 26, 2006 | 03:57 AM
craigo'sznprgrs's Avatar
craigo'sznprgrs
Default I understand the p300 codes the TN throws, but....
This morning, I was driving the car over to get the a/c repaired (another story alltogether), anyway, I had to merge into traffic, so since my car was recently tuned by Sharif (awesome tune), I punched it hard, the car didn't hesitant or anything, but the SES light which has stayed on since the tune, began to flash.
I know when you get these cars where they are running under 11:1 a/f ratio, the codes are more apt to come on, but I have never seen my SES light flash, then just stay on, should I be concerned at all? The car is otherwise perfect, boost is right on, egt is good, a/f's are about 10.6-10.8 under WOT.
Thanks in advance.
Craig
Old Jul 26, 2006 | 04:10 AM
taurran's Avatar
taurran
The turbonetics kit doesn't thow p300 codes. Other issues do.
I wouldn't say it's a perfect tune if you're running 10.6-10.8:1 AFR's at WOT? I'm wondering how you're running 400whp if so.
Perhaps you should check to see if you've fouled plugs.
Old Jul 26, 2006 | 04:16 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
i get P300 codes all the time, i thought it meant i was going too fast...
ill have to look into that
seems a little rich but safer...
actually at work we had a meeting that said "safety is the key!!!"
so i am running 8 peak timing with 9 to 1 AFR now the whole time..
Old Jul 26, 2006 | 05:37 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Safe a$$ set-up right there....
Old Jul 26, 2006 | 06:06 AM
EM-EFER's Avatar
EM-EFER
It probably looks like a diesel goin down the road.
Old Jul 26, 2006 | 08:42 AM
D350Z10's Avatar
D350Z10
The flashing of a ses light usually could mean cyclinder misfire.
Old Jul 26, 2006 | 08:54 AM
002-M-P's Avatar
002-M-P
Yes, flashing means cylinder misfire.
It also happened to me one time when i was running out of gas though.
Old Jul 26, 2006 | 09:00 AM
rs350z's Avatar
rs350z
I throw p302 twice so far on with UTEC on the TN. I just got one yesterday erased it with arader then it goes away temporary releif I really wish there was a UTEC tuning class I could take to do this **** on my own!!!
Old Jul 26, 2006 | 12:16 PM
Audible Mayhem
My350z
302 means cylinder 2 misfiring, probably a bad coil.... throw another coil in and see what happens and make sure the plug is good...
Old Jul 26, 2006 | 12:57 PM
booger's Avatar
booger
I had a injector wire harness clip for # 2 cyl. not pushed down all the way . Cyl would misfire off and on . Only got the P0300 code and it would blink ten times off and on also
Old Jul 26, 2006 | 01:00 PM
G3.5T's Avatar
G3.5T
FWIW I have never thrown a p0300 code with my TN set up. Maybe I got lucky.
Old Jul 26, 2006 | 04:40 PM
TTRANK's Avatar
TTRANK
I have gotten the P300 code. The definition is multiple cylinder misfire. Mine was being caused by my water/meth kit injecting too much water. I fixed the problem and replaced my plugs and have not had the problem since.
Old Jul 26, 2006 | 04:57 PM
Peking's Avatar
Peking
Thanks in advance.
Craig
Man since having the TN kit, my SES light stays on Sometimes it goes away for a day or so, but then comes back... In all that time, only once did the SES actually blink on and off... I called MIAPLAYA exactly when it happened, he explained that it could have been misfiring in a specific cyl or mutliple cyl... I can't really remember what exactly he said, other than I should really be worried it it keeps happening, and it has never happened again since then so IDK.
Gonna have to get a code reader one of these days.
So I say Craig, if it continues then def. something that needs to be checked out ASAP. Though if is does not happen again, I wouldn't be to concerned.
Jonathan
Old Jul 26, 2006 | 05:08 PM
BoOsTedz33TT's Avatar
BoOsTedz33TT
i did a search for cel light codes, didnt find chit, i just picked up my car from JOTECH, i had a cel light on, my car was running way to ric, because it ran to rich, it threw a cel light and made it run more rich, i had a 10.0 Af at idle when i threw a code, i did a new retune, actually just a basic upgrade for 145.00 and im back in the game
Old Jul 26, 2006 | 05:27 PM
craigo'sznprgrs
Jonathan
I have a code reader and I have thrown a p306 in the past, went away. I checked the code again and it was a p304, not flashing, but now even after I clear it, it will come back on? Oh well, I don't believe I will worry about it unless it flashes again. I am supposed to go back to Forged on the 12th anyway, I will ask Sharif if he minds taking a look then.
Old Jul 26, 2006 | 05:52 PM
TheCajunStyle's Avatar
TheCajunStyle
P0300 - P0306 are caused by any of the following events:
Improper spark plug
Insufficient compression
Incorrect fuel pressure
The injector cicuit is open or shorted
Fuel injector
Intake air leak
The ignition signal circuit is open shorted
Lack of fuel
Signal plate
Air fuel ratio (A/F) sensor 1
Incorrect PCV hose connection
There are 7 pages in the FSM dedicated to troubleshooting this code. You need access to the Consult-II system. Good luck on that one
My best advice: Be sure you have a proper fuel system setup, your tune is perfect and your plugs are good.
Old Jul 26, 2006 | 06:47 PM
Audible Mayhem
My350z
its kinda funny now cause if my SES light is off, then i think something is wrong!!
Old Jul 26, 2006 | 07:49 PM
Peking's Avatar
Peking
Yeah man. We talking the 12th of August?
Improper spark plug
Fuel injector
Intake air leak
Lack of fuel
Signal plate
Well that is quite a few things to sort through
Muhahahhahhaha, that is exactly what I think when the SES light goes away... I can't help but think I might have burned the light out, then strange as it sounds I feel better when it comes back on cause I know the light is working
Old Jul 26, 2006 | 10:54 PM
MIAPLAYA's Avatar
MIAPLAYA
If the CEL is flashing it indicates that a misfire is occuring at that time. You better reverify your AFr.
Old Jul 27, 2006 | 03:48 AM
craigo'sznprgrs
August the 12th, you want to go?
