Post Up Your F/I Maintenance Schedules
Old Aug 2, 2006 | 04:23 PM
JoneZZZ's Avatar
JoneZZZ
Originally Posted by JasiJ
Ok Noob question: Do you guys change your own oil? or take it some where. AND I don't mean Jiffy Lube!
I get oil changes at my tuner shop(GRD)...I get a chance to talk over issues ask questions and they get a chance to do routine checks on my car also.
Old Aug 2, 2006 | 04:45 PM
taurran's Avatar
taurran
My car is so low, its a huge pain to work on. I usually just have it changed if the car is in the shop for something.
I've been thinking of getting four low profile ramps to pull it up on to do oil changes. I'm not even sure if it would be enough room. I guess I'd just have to get a dog food bowl or pie pan to put under there to catch the oil.
Old Aug 8, 2006 | 01:18 PM
scshay's Avatar
scshay
Sweet Thanks Guys This Helps Alot.
Old Aug 8, 2006 | 01:35 PM
MoodDude's Avatar
MoodDude
Oil Change - 3k or 4 track days (which ever comes first) - Mobil 1
Transmission Fluid - once a year , Redline
Diff Fluid - Every oil change, Redline
Air Filter - Every 6k miles Clean
MAF sensor - clean every air filter cleaning
Brake Fluid - Bleed once a month - completely change every 3 months
Inspect Brakes - once a month
Inspect supension - once a month
Inspect Tires/Wheels - once a month
Radiator - once a year
Cool down - all the time
I do all my own work.
Old Aug 8, 2006 | 01:53 PM
JoneZZZ's Avatar
JoneZZZ
What do you use to clean the MAF sensor?
Old Aug 9, 2006 | 07:17 AM
MoodDude's Avatar
MoodDude
With the oil type air filters, it is nessarary to clean the MAF sensor. They just came out with a product and GRM mag did a review and found that the cleaner data is accurate and highly recommend it. The cleaner I use is:
CRC Mass Air Flow Sensor Cleaner
Old Aug 9, 2006 | 07:31 AM
jpc350z's Avatar
jpc350z
How do you apply it?? Remove the MAF and spray..
Old Aug 9, 2006 | 12:23 PM
MoodDude's Avatar
MoodDude
You got it - remove, spray, let dry, install : all done.
Great idea for us who need the MAF to be accurate all the time. The oil from your filter can foul the sensor and give a miss reading. And when you FI a NA compression engine - that can spell trouble if the MAF doesn't read correctly.
Old Aug 12, 2006 | 04:43 AM
jazz z1's Avatar
jazz z1
MOODDUDE .... Can you get CRC Mass Air Flow Sensor Cleaner from any auto parts store? Or, do you have to special order it from a distributor?
Old Aug 12, 2006 | 09:44 AM
JoneZZZ's Avatar
JoneZZZ
Good tip......thanks.
Old Aug 12, 2006 | 10:17 AM
JoneZZZ's Avatar
JoneZZZ
Originally Posted by D350Z10
Oil- spark plugs check quite often replace 5k
I've been talking this over an thinking about it a bit.... think I am going to stick to an annual spark plug replacement schedule.
lapham3
Oct 7, 2022 03:15 PM
3vilbunny
Jul 18, 2017 05:10 PM
Tochigi_236
Sep 27, 2015 03:40 PM
