Post Up Your F/I Maintenance Schedules
I have gotten a lot of PM's from folks interested in F/I, and pro's/cons oof one kit vs another. A couple of folks on the forum have made the statement that I belive in "F/I is not a cheap proposition"......they are right.
The designers of these F/I solutions have put a lot of time into their products. In my view, it is the purchasers job to fully research what the solution is intending to do(some products achieve a F/I solution differently....gotta understand the impacts)......fully understand what F/I is and finally.....the purchaser has to MAINTAIN the product and its design intent.....
To that end, for those with F/I, post up your Maintenance schedules(post your kit type and schedule).
Mine.....
APS/ST on a 5AT coupe
Oil..............synthetic...........................changed every 3K miles
Coolant.......standard green stuff............checked everytime I put 'her' away.
flush every 2yrs.
Leak Check..........gaskets, etc............................weekly
5AT Tranny flush.......Matic-J...........................every 25K(since F/I)
Cool-down..............................................EVERY TIME I DRIVE IT
Mine.....
flush every 2yrs.
Stillen Stage 4 SC on 6MT G sedan.
Oil....M1 Synthetic....every 3k
Coolant....standard green stuff....every year
Tranny and rear dif....Redline (MT90 and 75W90)....every 6 months
Belts....Gates....Check about every two weeks and replace/tighten as needed
Cool down........I live in Phoenix; it never cools down, neither does the SC (ha-ha)
Oil- Royal purple 10w40 synthetic 2000miles
Coolant- normal flush out every summer 6 months of driving.
Trans/brake/clutch fluid check every 5k
Clutch fluid motul 3000 somthing stock would heat up to quick
spark plugs check quite often replace 5k
Cool Down- car alwayz stays cool, coolant overflow is always the same, same temp.
Pulley belts- never needed to.
Originally Posted by D350Z10
spark plugs check quite often replace 5k...
5k replacement schedule.....thanks. Will see about getting this done this week-end.
Originally Posted by TIMMAHH
Wow 5k? I plan on changing mine every ~10-15k and thought that was almost too often. They are like $70-80 for a set.
D350Z10 and TIMMAHH, thanks for your input on this, I am going to get my plugs changed this week-end(24K boosted miles).
oil - 10w40 AMSOIl Synthetic changing every 2500 miles
Coolant - Distilled Water and Water Wetter once a year
LSD/Tranny - AMSOIL about 9 months ago
All other fluids and Brakes check every 2500 miles
Spark Plugs...get new ones with engine build next week
Belts - never needed to
Cool Down - always
Cool Down - always
Originally Posted by taurran
I was using Amsoil until I burned off a ton on my last road trip. I'm using basic Mobil 1 10w-30 now. I'm not even sure anything else is worth the extra money.
ideally you'd do it twice a year, in the summer and in the winter to double check everything is where it should be and adjust for the different weather
depends on your setup and EMS though
Oil: Royal purple 10w40 every 3000miles
Coolant: Synthetic Coolant with Royal Purple "Purple Ice" additive every year
Trans/Diff: Royal Purple change year
Brake/clutch: Motul RBF 600 every 6 months
Spark plugs: every year
Cool Down: always cool down before shutting off.
I just change my oil every 2k miles to be on the safe side still haven’t changed tranny or differential fluids and every once in a while I listen for any unusual noises or look at my rad fluid
I drive 6 months through the year maybe and during those months put a max of 5k miles on usually i drive 3k in those months. The Z is the weekend car!
Ahhh that helps. I drive about 1200-1500 a month lately so that was $
$ to me. But that often is not so bad.
Lets see...
Greddy TT 6MT...9psi...481whp...39k miles on engine...32k miles on turbos
Oil: Mobil 1 or Amsoil 10w-30 every 2500-3000miles (I switch between the two sometimes)
Coolant: Normal Green Coolant about every year (no set schedule)
Trans/Diff: Just changed Diff with Mobil 1 75w-90 at LSD replacement for the first time at 35000miles and about to change tranny in the next couple of weeks. (Diff is loud with Mobil 1...will switch to Redline)
Brake/Clutch: ATE SuperBlue/Type 200 (no set schedule)
Sparkplugs: 1-step colder NGK Copper (check every 10k or so, replace when needed)
Cooldown: Everytime from a hard run, or drive a few miles at low engine speeds
