I canīt add more fuel ( APS TT )
Old Aug 7, 2006 | 09:08 PM
Julian@MRC's Avatar
Julian@MRC
Originally Posted by phunk
amy: i dont know much about that stuff really
bullitproof: the over all max will depend on the engines efficiency in using the fuel that it is given... so more aggressive tuning and higher CR's will lead to greater power output... which will explain why guys with stock engines (high NA CR) can hit 500rwhp with the included fuel system.
And also dont forget the more agressive the tune on a stock engine, the more prone you are to melting pistons or detonating to pieces.
Old Aug 8, 2006 | 05:37 AM
Bullitproof's Avatar
Bullitproof
oh.
Old Aug 8, 2006 | 06:08 AM
Julian@MRC's Avatar
Julian@MRC
Seriously, the idea of a Super AFC on top of a UNI-CHIP is a really really bad idea..Your modifying and already modified fuel trim signal..Just IMO not the best solution or safest thing to do..
Old Aug 8, 2006 | 06:16 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Since you do not have access to a Unichip tuner, your best solution would be to remove the Unichip, and run a UTEC, and upgrade to a slightly larger injector while you are at it.
How much power are you looking to acheive? Anything beyond 500whp, and I would strongly consider a CJM return fuel system.
Old Aug 8, 2006 | 07:10 AM
al_v's Avatar
al_v
I will replace the REV-UP lower plenum by the stock lower plenum , this will reduce my peak hp , and my fuel related problem.For now ,this is all I can do....
In a near future , I will get some kind of EMS , bigger injectors , and a complete fuel return.Iīm thinking in 520-530rwhp.
Sharif , when the UTEC have the ability to raise the rev limiter, in ī05 cars, please let us know.
Old Aug 8, 2006 | 07:20 AM
Alberto's Avatar
Alberto
Cranky FI Owner
On my car the revup lower plenum made me lose power and TQ compared to the stock plenum....
Old Aug 8, 2006 | 07:32 AM
al_v's Avatar
al_v
With the rev-up plenum you will lose tq , but definitively make more hp ,in the 6000+ rpm.
Old Aug 8, 2006 | 08:28 AM
Sharif@Forged
Forged Performance
Will do. But honestly, even on the rev up motor, there will be little need to raise the rev limit beyond the factory setting.
Old Aug 8, 2006 | 08:43 AM
Julian@MRC's Avatar
Julian@MRC
Unless you use cams and valvetrain.
Old Aug 8, 2006 | 08:52 AM
BrianLG35C's Avatar
BrianLG35C
So there's no way to get over 470-500whp with the Unichip? Even with upgraded actuators or cams?
Old Aug 8, 2006 | 09:00 AM
Julian@MRC's Avatar
Julian@MRC
no we were reffering to the rev limit..No use raising it unless you have cams and headwork..
Old Aug 8, 2006 | 09:06 AM
al_v's Avatar
al_v
But I donīt have a rev-up motor , I have the lower plenum only , and if you can get the high hp produced by the rev-up lower plenum , you will need at least 7100-7200 rpm.
Old Aug 8, 2006 | 09:08 AM
al_v's Avatar
al_v
Iīm in the limit with 450 rwhp , with a CR around 9.3:1.
Old Aug 8, 2006 | 09:10 AM
Julian@MRC's Avatar
Julian@MRC
Your at the limit of fuel you can flow with the fuel system and the efficiency of your motor.
