greddy e-01 issues
Old Aug 19, 2006 | 01:25 PM
mazx6's Avatar
mazx6
Default greddy e-01 issues
Hey guys..
I had my car tuned/dynoed and boost was great. It carried 9 psi perfect. Something werid is going on now though.. When ever i boost it comes on great then falls back down to almost zero then tries to come back up. I thought it might be a waste gate problem, but i turned to boost controller off and 5 psi is nice and smooth. With the boost controller on it hesistaes really bad. Anyone have any experiance with these controllers?
I tried it both on manual and auto. and the same thing happens every time.
Old Aug 19, 2006 | 01:41 PM
chimmike's Avatar
chimmike
there's no way it's a controller problem if boost comes on then falls to zero..........boost will never go below the wastegate spring setting unless the spring is changed or there is a leak.
Old Aug 19, 2006 | 01:52 PM
mazx6's Avatar
mazx6
SORRY
What ment to say was it was going back down to stock boost. I was thinking about what the graph looked like and thought of zero. When i graph the boost out it, it comes on smooth and the has a quick drop down to wastegate spring pressure then tries to shoot back up to 8-9psi
Old Aug 19, 2006 | 02:13 PM
chimmike's Avatar
chimmike
what is the gain set at (if there is such on the e-01) ?
Old Aug 19, 2006 | 02:41 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
maybe a leak in the line going from the boost solenoid to the wastegate or to the boost solenoid, check all your lines...
Old Aug 19, 2006 | 09:05 PM
mazx6's Avatar
mazx6
gain is set on 10 and i check all vacuum lines... no leaks. Maybe a solenoid?
Old Aug 20, 2006 | 11:20 AM
mazx6's Avatar
mazx6
bump
Old Aug 20, 2006 | 07:21 PM
mazx6's Avatar
mazx6
I also have a J&S safegaurd on the car, think that would be a factor?
Old Aug 20, 2006 | 08:22 PM
westpak's Avatar
westpak
SFZCC
No.
If you are shooting for 9 psi set you start boost at 7 psi, do a datalog with the e01 and lets see what the boost is doing vs rpms
sherm
Apr 11, 2020 05:21 PM
sales@czp
Sep 23, 2019 03:30 PM
350z82
Oct 1, 2015 06:25 PM
