Overboost cut on T-netics
Old Sep 6, 2006 | 02:36 PM
g356gear's Avatar
g356gear
Originally Posted by MIAPLAYA
One thing I haven't seen mentioned is the voltage clamp setting. If you clamp it lower what happens? Sounds like the MAF is going over voltage and may not actually be bad...
Mia....does the re-flash clamp the voltage seen from the MAF by the ecu?? If so, what do they clamp it at?? Higher than 4.7 volts on the UTEC??
Old Sep 6, 2006 | 05:21 PM
MIAPLAYA's Avatar
MIAPLAYA
No the reflash does not clamp the voltage at all. Are you sure the voltage clamp is not adjustable on the UTEC? It is on the Emanage and other tuning
Old Sep 6, 2006 | 05:44 PM
g356gear's Avatar
g356gear
Nope....checked with Sharif and he confirmed it is non-adjustable on the UTEC.
How is it then that the car does not go into limp mode with the T-netics kit without a voltage clamp??? The airflow of a boosted car should max out the N/A MAF at only a few PSI.
Old Sep 6, 2006 | 06:12 PM
chimmike's Avatar
chimmike
it doesn't until 6-7psi.
Old Sep 6, 2006 | 06:31 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
mine doesnt max out the maf until right over 10 psi. plus mike, even though it "says" that if you put the utec on map 0 it is running stock, well it isnt, the utec still does some weird stuff.
it made my NA car run like crap on 0.
is the parameters on the utec set to take over at 20-25 percent throttle??
if so the maf has nothing to do with the injector pulse widths any longer
Old Sep 6, 2006 | 09:15 PM
g356gear's Avatar
g356gear
If this is the case then why do the UTEC and the Greddy E-manage clamp the MAF voltage under 5.0 volts??
Old Sep 6, 2006 | 09:20 PM
in2therain3's Avatar
in2therain3
Mine did the same thing but in the rain. It did happen the next day when the day was nice. The AEM filter that came with the kit is not oil based and after opening up the pipe for the MAF, I saw water spots all over it. I didn't drive through any ditches of water, just hard rain. I actually switched out the filter to a K&N one since it is a oil based filter. Anyhow, could have that caused damage to the MAF??
Old Sep 7, 2006 | 03:00 AM
Audible Mayhem
My350z
yeah, i am going by dataloggin using 1 on the utec and following the psi verses maf voltage, it will max out at 5.0 on mine but it does it right over 10 psi. thats why i think its crazy when people are saying they are close to maxing out the maf NA..... right...
Old Sep 7, 2006 | 04:40 AM
QuadCam's Avatar
QuadCam
Mine maxes out at 5.0V as early as 3800-4000 rpm with 6-7psi of boost.
unfortunately, boost isn't a very good reference to look at....as boost is not related to airflow. It is only a measurement of pressure in the intake mainfold.
A very basic ananolgy would be this: it will take twice as much airflow to make 10 psi of boost at 6000 rpm as compared to 3000 rpm.
whatever your case may be, you will definately max out the stock MAF meter with only a mild amount of boost at mid range rpms.
Old Sep 7, 2006 | 05:56 AM
MIAPLAYA's Avatar
MIAPLAYA
On the dyno in Cali Turbonetics ran my car up to 12 PSI before the MAF maxxed out.
Old Sep 7, 2006 | 06:44 AM
QuadCam's Avatar
QuadCam
I am going off of my UTEC datalogs.
sales@czp
Sep 23, 2019 03:30 PM
BEBO'S ZEE
Jun 7, 2016 07:48 AM
Tochigi_236
Sep 27, 2015 03:40 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
