Anyone know how to diagnose VDC?
Old Sep 16, 2006 | 04:24 PM
phunk's Avatar
phunk
CJ Motorsports
Default Anyone know how to diagnose VDC?
I figured I would ask here, cause most of us turbo guys have had our steering shaft off a couple times.
Is there a way to get the VDC light to flash codes and tell you what it is unhappy about?
My VDC light comes on the moment I start to roll away from a stop after just starting the engine. More than likely, somewhere along the way I messed up the calibration of the steering shaft and/or steering wheel, having had both out a couple times.
What is interesting, is that the VDC actually engages for a moment before it turns the light on. So its trying to do something.
Its clear to me that the steering position sensor is not properly calibrated right now, and when I pull away straight it thinks my steering wheel is turned, and then the VDC computer is seeing all 4 tires going the same speed so it thinks that I am slipping - since all 4 tires should not be the same speed if it thinks the car is turning.
Thats my best guess anyway.
So anyone know how to either check for VDC codes, or how to recalibrate the steering wheel position sensor? Maybe I am blind, but I cant find it in the service manual.
BTW, my car is running again Dyno numbers coming soon
Old Sep 16, 2006 | 04:59 PM
meatbag's Avatar
meatbag
Have you tried unplugging the Fcon and just let the stock ecu run the car and scan for codes?
Old Sep 16, 2006 | 05:13 PM
phunk's Avatar
phunk
CJ Motorsports
i can scan for codes anyway, but i dont think the VDC troubles will show up in a standard OBDII scan, I would need a Consult
Old Sep 16, 2006 | 06:02 PM
BoOsTedz33TT's Avatar
BoOsTedz33TT
re-align the steering column, and reset the code...
Old Sep 16, 2006 | 06:09 PM
phunk's Avatar
phunk
CJ Motorsports
I would love to... but how do you know when you have the steering angle sensor centered/aligned?
Old Sep 16, 2006 | 06:24 PM
Goerge@GTMotors's Avatar
Goerge@GTMotors
PEACE OF CAKE
FROM THE SUB MENU OF THE CONSULT II SELECT ABS ,THEN GO TO ECU INPUT AND YOU ARE GOING TO SEE YOUR CURRENT ST ANGEL SENSOR READING,IT SHOULD BE @ -2 +2 DIGRESS WHEN THE ST WHEEL IS STRAIGHT ,IF YOUR ST WHEEL IS OFF THEN YOU SHOULD PUT THE CAR ON THE ALIGNMENT MACHINE CENTER YOUR ST WHEEL WITH WATCHING YOUR ST ANGEL READING ,OR JUST REMOVE AND REPOSITION THE COUPLER .
SAM
GT MOTORSPORTS
Old Sep 16, 2006 | 06:25 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
OR... take up the center console and take out the VDC like real men do !!!!
Old Sep 16, 2006 | 06:33 PM
failsafe306's Avatar
failsafe306
The dealership was able to recalibrate mine when the same thing happened.
Old Sep 16, 2006 | 06:46 PM
phunk's Avatar
phunk
CJ Motorsports
Originally Posted by GTM
PEACE OF CAKE
SAM
GT MOTORSPORTS
Sam, killer! Now how much is it to rent your Consult for a couple days?
-Charles
Old Sep 16, 2006 | 06:47 PM
phunk's Avatar
phunk
CJ Motorsports
theres another idea! maybe when i get the race logic.
phunk's Avatar
phunk
CJ Motorsports
that was my next plan, but i just hate going there when i know i can do it myself - and i also fear i will end up with a tech that has no idea how to do it.
Old Sep 16, 2006 | 06:51 PM
BoOsTedz33TT
just find a cool tech, me, personaly when i deal with a nissan service BS, i always meet the tech, tell him WHAT NEEDS TO BE DONE, in a nice way, as to save him hours of troubleshooting, then i tip a him 20 bucks for lunch, and say thank you.
its sucks you gotta kiss ***, but if you kill them with kindness you cant lose...
Chris350z03
Oct 8, 2023 07:19 PM
aarrgghh
May 1, 2022 11:04 AM
Dr.Paulyy
Jul 29, 2019 07:45 AM
HoneyBadgerRy
Sep 21, 2015 03:25 PM
