Ses P1274 P1283 P302
Old Oct 31, 2006 | 10:42 AM
  #41
LODOSS's Avatar
LODOSS
don't have anything to check with =( i just reset car .. no codes yet but i am sure they'll come back. my car does not ping anymore.. i know beforei clear it in 2nd 3rd med thorttle going for 2000-4000 i can hear it ping.. very slightly
Old Nov 25, 2006 | 11:12 PM
  #42
G3.5T's Avatar
G3.5T
Originally Posted by MIAPLAYA
Still being looked at by the R&D guys at Turbonetics. Sorry guys I'll give an update as soon as I get one.
Mia, have you gotten anything from R&D on this issue?
Old Nov 26, 2006 | 09:43 AM
  #43
MIAPLAYA's Avatar
MIAPLAYA
Actually no and to tell you the truth I completely forgot. Sorry I dropped the ball, I'll ask them Monday.
Old Nov 30, 2006 | 09:03 PM
  #44
G3.5T's Avatar
G3.5T
Anything yet?
Old Dec 5, 2006 | 03:59 AM
  #45
G3.5T's Avatar
G3.5T
Old Dec 5, 2006 | 05:09 AM
  #46
down_shift's Avatar
down_shift
To be honest, this sounds like a different issue man
Old Dec 5, 2006 | 05:10 AM
  #47
down_shift's Avatar
down_shift
My CEL has actually been off for 3 weeks now. It turned off by itself. Very odd since it's been for almost a year.
Curious to find out if the temperature to how rich I'm running has anything to do with it...
Old Dec 5, 2006 | 04:19 PM
  #48
G3.5T's Avatar
G3.5T
How many miles since you reset it? I just reset mine since it has gotten pretty cold here. I was wondering the same thing, if the outside temperature was going to play a role.
Old Dec 5, 2006 | 06:38 PM
  #49
down_shift's Avatar
down_shift
I didn't reset it.. it turned off one day when I turned it on..
It's been about 200 miles and 3 weeks now. (I've driven it prob 5 times since last month)
Let's hope TN is still check up on this!
Old Dec 5, 2006 | 11:12 PM
  #50
G3.5T's Avatar
G3.5T
Not holding my breath anymore
Old Dec 5, 2006 | 11:13 PM
  #51
MIAPLAYA's Avatar
MIAPLAYA
Not expecting you to hold your breath. I asked if there were any updates but haven't heard back on it yet. I'll ask again.
Old Apr 5, 2007 | 08:07 AM
  #52
QuadCam's Avatar
QuadCam
I am still getting these codes even though I no longer have the TN kit. I am now running a Greddy TT. hmmmmmmmmm............
Could it be a UTEC issue? Could it be a stock ECU issue? Or an injector issue? Here's what the service manual says for my P1274 and P1283 codes. It is defiantely the upstream O2 which are reporting this. The downstreams only tell the ODBII system if the cats are funstioning.
Old Apr 5, 2007 | 08:14 AM
  #53
Audible Mayhem's Avatar
Audible Mayhem
My350z
i say we have a contest who can get the most codes, i am over 20 now every time i check it!!
Old Apr 5, 2007 | 08:18 AM
  #54
Kenk2's Avatar
Kenk2
Professional
Not throwing any codes.. yet..
Could something be wrong?? lol
Old Apr 5, 2007 | 08:47 AM
  #55
QuadCam's Avatar
QuadCam
I have been getting these codes every since going FI.
It is wierd because the codes are saying that I have one bank that is lean and the one is rich.
Old Apr 5, 2007 | 08:54 AM
  #56
down_shift's Avatar
down_shift
Haven't had the codes for about 4 months now.. 4 months, 900 miles to be exact.
Let's hope it stays this way.
What I did was I went under the car and took the o2's out and cleaned them up.. then threw them back on. I also tried swapping them but ended up swapping back. The codes did come back as pending for a few starts, but I kept clearing them... I haven't cleared it since... mid January.. I'll keep you guys updated though. I have a feeling the ecu is confused sometimes at what's going on rich/lean wise.
Old Apr 5, 2007 | 09:18 AM
  #57
Kenk2's Avatar
Kenk2
Professional
Andrew,
Try unplugging the Neg. terminal to the battery and leaving off overnight..
I was throwing some of the same codes when I was having problems with my fuel return.. I fixed the problem, retuned as I was really lean and still had the codes.. While I was hooking my guages up, I removed the neg. terminal for a few hours and when I hooked it all back up, the codes were gone and haven't showed up..
K
Old May 16, 2007 | 06:26 PM
  #58
oneandonly5680's Avatar
oneandonly5680
Had to jump in on this one, I just recently had the TN kit installed, actually it was 4 days ago and I am now getting the P1274 code. Any word on what might take care of this. I have an 05' 350z.
Old May 16, 2007 | 07:21 PM
  #59
rcdash's Avatar
rcdash
If you swap sensors and the codes reverse then I would suspect the DTC condition is true. Otherwise the sensor that reports the error is bad. I would think... Has anyone tried replacing the O2 sensors?
Old Mar 21, 2008 | 07:51 PM
  #60
ChrisCJ99's Avatar
ChrisCJ99
ok. So any luck with these codes??? I just recently installed my TN kit and I got a 1284 code. Where can I get these spacers people are using???
