**I'm BACK** With a Forged Build, Twins, DD vs DJ comparison and more**
Old Oct 18, 2006 | 06:45 PM
  #481
BobbyRitz's Avatar
BobbyRitz
Ace-
It's my understanding that the Level 5's are stock inside the CV boots. Brent (BamBam) busted his DSS level 5's on drag radials when we rented MIR out.
Old Oct 18, 2006 | 09:00 PM
  #482
thawk408's Avatar
thawk408
Originally Posted by aceman
I found the pic
They do look stronger, Get a set of them Alberto You should be good to go then.
Later
Aceman
Looks a lot like an 03-04 cobra axle.
Old Oct 19, 2006 | 04:09 AM
  #483
Alberto's Avatar
Alberto
Cranky FI Owner
Originally Posted by BobbyRitz
Hey...we all have our talents, no? After all, you drive a snake. The question is...do you have one?
LOL...thanks, though. It turns out that the original mid pipe that I received from "shop not named here" was a y-pipe from a G35. I worked with R Stempler Nissan near me to work out my issues.
Bigbri-
I respect everything you've done on this site. My money is on Alberto, bro.
Rob-you know I love you man, but that sounded really gay
Old Oct 19, 2006 | 06:58 AM
  #484
MI 35th's Avatar
MI 35th
OGPremierMafia
I have no money to bet!
I am going to have to go with peak power though over quicker spool!
And you guys wonder why supras win all the damn time... Cause thats all they need! Is time to spool the friggin huge turbo!
Old Oct 19, 2006 | 07:00 AM
  #485
Alberto's Avatar
Alberto
Cranky FI Owner
Peak power over area under the curvve = you lose down the 1/4-its different on the highway on runs to 180mph....MI35th FTL!
Old Oct 19, 2006 | 07:12 AM
  #486
doug's Avatar
doug
Originally Posted by bigbri
I'll race all of you and give you a 2 car start... Did I mention my car is boosting 23lbs again???
i will race you and give you a 4 car head start to 190
Old Oct 19, 2006 | 07:55 AM
  #487
BobbyRitz's Avatar
BobbyRitz
That's aiight...
Old Oct 19, 2006 | 07:20 PM
  #488
BamBam's Avatar
BamBam
Hehehe, Im not sweating it. You need to give him another 150whp over me to keep the same power/weight-remeber his car is heavy Even then, traction will be bad for him as he cant fit slicks over those huge rear brakes....we'll set it up when he gets back from Japan.
LOL... well I would not run anything but DR's because I want a little bit of control at those speeds... We know I can fit 18x305s easily, I can probably move up to 315's if I pull the fenders a bit more. As for power... lets see what Sharif comes up with... but I figure we can hit 150+....
As for the axels, I would definitely wait for the DSS Level 5's and if you are serious about everything, the suggestion by Vinny Ten is to weld the inner CV joint to prevent that type of failure I had last time at the track...
I don't seriously expect to beat you Bert.. you drive your car WAY too hard for me, and have a lot more expereince then I do. But it would be fun to see a couple of 10 sec runs...
--B
Old Oct 19, 2006 | 08:12 PM
  #489
BamBam's Avatar
BamBam
LOL... I am thinking I can match you here shortly... what have you done to prevent the all so familar busted axle or tranny?
Old Oct 19, 2006 | 08:27 PM
  #490
BamBam's Avatar
BamBam
LOL^^
Todd, I have never seen a side by side pic. The axle stubs are much thicker, beefier units. Same on Level 2 as on level 5. Stock inner and outter joints on Level 2though, and stock inners on Level 5's with better outter cv joints. You'd think for the $$$ the Level 5's would be all beefed up...I saw somebody break Dss 5's@ MIR, but I think it was driver error than anything else.
Driver error... come on man... I might not really know what I am doing, but at least 2 of us busted axles that day on that one track. True I was trying something new with the DR's (at your suggestion I might add.. LOL )
I have spoken to DSS and they swear they have never seen a busted inner CV joint, therefore they did not see a need to beef it up. After talks with Vinny, it appears he uses them all the time, BUT he modifies them to take the additional stress AND his race cars are about 1000 lbs lighter so less strain on launching. Anyway, after looking at the exploded inner CV, it was deciced the joint was probaly already damaged from my earlier days at the track on the stock axles. So it was already weak and the added stress of launching on DR's, + a harder launch from about 5K took the weakest point and busted it.
Everyone needs to keep in mind, that if you beef up the axles, then the next weakest point will fail given enough stress (Tranny...?). Our cars are not designed to push that much weight, that fast down the 1/4. Do it often enough and something will definitely break. That is a given.
We all know the saying, pay to play...
Bert, it sounds like you are making the right decision to wait until you get the level 5's (have them check the inner CV joints you already have or buy new ones while doing the swap).
I think we will have to set up another MIR day early next year for som
--B
Old Oct 19, 2006 | 09:01 PM
  #491
bigbri's Avatar
bigbri
I don't drag my car on slicks heat up the tires and run a 1.5-1.8 60' I don't care about what kind of axles you guys get..Good luck with that tranny holding up after a couple of hard launchs... Glad you getting you car fixed by Sharif he knows his **** and you'll have my power lever if not more..
Old Oct 19, 2006 | 09:20 PM
  #492
BamBam's Avatar
BamBam
Yea, that is what I figured. I won't use slicks either. Looking at that line lock kit to help me heat up the tires and go with a slightly softer launch.
If I run more then a couple of runs, I figure I will need to look into welding the inner CV's and I already have my eye on a new tranny... That Dogtooth looks like it could be a lot of fun..
Working on a higher tune next week I beleive, but so far things are just a little odd with the engine. Nothing outright, but just not developing the power we expected at set boost levels. I leave it in Sharif's hands to get it worked out the best it can safely be done.
--B
Old Oct 19, 2006 | 09:28 PM
  #493
meatbag's Avatar
meatbag
I found the pic
Later
Aceman
Hey those are my axles.
Old Oct 19, 2006 | 10:30 PM
  #494
Acree's Avatar
Acree
I love how there's a wine rack next to it. Shows just what kind of people we have on the boards.
[bad english accent]
"More wine Henry?!"
-"Well by George, if I do say so myself, I'll have anotha!"
[/bad english accent]
-Acree
Old Oct 20, 2006 | 07:49 AM
  #495
Alberto's Avatar
Alberto
Cranky FI Owner
--B
Brent I didnt mean any offense by that statement. I have watched your video over and over, as well as being right behind you when it happened, I think you let your clutch out a fraction of a second before you got on the gas, essentially shocking the drivetrain. Doesnt really matter, stuff breaks when you race. One thing is for sure!-->MIR prep'd that track too much, it was way sticky for the cars/power levels/experience that day, Im honestly surprised more people didnt snap axles. What you bring up in regards to welding the inner CV joint is interesting. Id love to set-up another track day without a doubt though Brent, we can put some nice #'s up for MD Z's to compete with these loud mouth FL guys ie. Jeremy
edit-fwiw slicks are easier on your drivetrain than DR's...
Old Oct 20, 2006 | 08:13 AM
  #496
doug's Avatar
doug
its one thing to talk about it... ok i get excited... its another thing to show me pictures... ok i get excited again..
but all my excitement for jeremy's car ran out 2 months ago.. until i see that thing come out with a dyno sheet or make a run down the 1/4 mile.. its all hype for now..
yes i am blunt.. but i can only dream for so fcking long
somebody wake me up when either or happens.. because right now its as much hype as a stock Z... ow wait.. a stock Z runs
Old Oct 20, 2006 | 08:46 AM
  #497
kalima275Z's Avatar
kalima275Z
Em r fightin' werdz!
Old Oct 20, 2006 | 08:54 AM
  #498
doug's Avatar
doug
Old Oct 20, 2006 | 08:58 AM
  #499
ZU L8R's Avatar
ZU L8R
Viper Sellout
wait no longer, he's going tonight. No TH400 though
Old Oct 20, 2006 | 09:00 AM
  #500
Alberto's Avatar
Alberto
Cranky FI Owner
My thread is officially homo status, thanks you d!cks....j/k
