strange noise...sounds like a pigeon.
Old Sep 25, 2006 | 09:13 AM
QuadCam's Avatar
QuadCam
Default strange noise...sounds like a pigeon.
Every time I let off the throttle after light boost (1-3 psi), I immediately get a sound that sounds like a pigeon cooing. I thought that I was being overly sensitive about it, but even my wife asked what the noise is.
It is a fluttering sound, but I'm pretty sure it is not the BOV. That makes a different sound, even at lighter louds. I was thinking that maybe something is rubbing underneath the car, but it feels liek it might be clutch related, somehow.
anyone else have the mysterious pigeon under hood?
oh yeah, I have the TN kit.
Old Sep 25, 2006 | 09:30 AM
MIAPLAYA's Avatar
MIAPLAYA
Could be the preload on the BOV. Have you tried tightening it?
Old Sep 25, 2006 | 10:11 AM
350Zteve's Avatar
350Zteve
My Supra made funny sounds when I had a hole in one of intercooler piping connectors. It was a fluttering whistle sound.
Old Sep 25, 2006 | 10:30 AM
drumma022's Avatar
drumma022
Light Compressor surge possibly?
Old Sep 25, 2006 | 10:41 AM
MIAPLAYA's Avatar
MIAPLAYA
Very doubtful. i had this happen about a month ago and figured out that my BOV preload was too light. (I had pulled the BOV to clean everything and messed with the preload adjsuter at that time). Tightening it back up fixed it.
Old Sep 25, 2006 | 10:42 AM
QuadCam's Avatar
QuadCam
i though about compressor surge, but you don't hear the noise at higher boost levels - when you let off.
Old Sep 25, 2006 | 10:43 AM
QuadCam's Avatar
QuadCam
how much should you tighten it? how many turns? or half-turns?
Old Sep 25, 2006 | 12:42 PM
Trav4011's Avatar
Trav4011
It's compressor surge.. if you loosen the bov a little, that will probably solve your problem. I wouldn't really worry about it, though.. unless the sound just bothers you. Light surge, at partial throttle/light boost situations, won't hurt anything.
Travis
Old Sep 25, 2006 | 01:02 PM
MIAPLAYA's Avatar
MIAPLAYA
Heres pic of the current setting on my BOV:
Old Sep 25, 2006 | 01:19 PM
BamBam's Avatar
BamBam
I used to get this sound at partial throttle. We always assumed it was the SSQV. To me it sort of sounded like a pigeon being strangled, but to others it sounded like cooing..
Now with the rebuild of my engine and complete overhaul of the TT setup, I have not been having these noises. I guess Frank fixed the problem..?
Old Sep 25, 2006 | 09:59 PM
Beer Goggles's Avatar
Beer Goggles
I called them turbo angry pigeons. I have a GReddy kit, stock without BOV, and I hear them all the time. Sometimes they are nice and some times louder.
Old Sep 25, 2006 | 10:03 PM
Ed 718's Avatar
Ed 718
BRAVEHEART
Could be Snakes Derek
Old Sep 25, 2006 | 10:32 PM
mchapman's Avatar
mchapman
Sounds like a small bird has been sucked into the compressor under boost and its complaining.
Old Sep 26, 2006 | 05:27 AM
QuadCam's Avatar
QuadCam
It looks like you have 9 turns visible. So........I went aout and looked at mine. I only had 6 turns showing. So I loosened it and by the time I back it out 2 more turns, the nut and the allen-head set screw fell off the BOV .
Aparently, you must have a longer set screw than the one on my BOV!
Old Sep 26, 2006 | 07:30 AM
MIAPLAYA's Avatar
MIAPLAYA
Give Reggie a call at Turbonetics and see if he can send you a new one.
Old Sep 26, 2006 | 09:30 AM
QuadCam's Avatar
QuadCam
i just left him a message.
Old Sep 26, 2006 | 09:38 AM
MIAPLAYA's Avatar
MIAPLAYA
If he's not at as his desk also ask for Steve or Ed when you call in support. Just let them know your BOV is not holding closed properlly and they will send you a new one.
Old Sep 26, 2006 | 09:42 AM
QuadCam's Avatar
QuadCam
should the BOV be open when idleing? I was looking at it while the car was idling, and the plunger was pulled back (vacuum) allowing air into the intake tract.
Old Sep 26, 2006 | 09:48 AM
MIAPLAYA's Avatar
MIAPLAYA
Mine does that so I have to assume it will.
Old Sep 28, 2006 | 12:28 PM
Ed 718's Avatar
Ed 718
BRAVEHEART
Good talking to you Andrew but like we discussed if it is the BOV we will help you with that.
