Weird Noise coming from Vortech Unit
Old Oct 2, 2006 | 08:11 PM
DMK's Avatar
DMK
Unhappy Weird Noise coming from Vortech Unit
Noticed it this morning. When I start my car, I get this distinct buzzing/rubbing sound coming from near the SC unit. It's quite different than the normal rattle/whirling noise that the Vortech usually makes. Have a appt. to get it checked out on Friday, but I was wondering if you guys could point me in the right direction as to what it is. I am kind of worried. Please help!
http://s114.photobucket.com/albums/n...t=MOV03078.flv
Old Oct 3, 2006 | 06:43 AM
617G's Avatar
617G
Is the belt on the pulley rubbing against the blower?
Old Oct 3, 2006 | 01:37 PM
booger's Avatar
booger
take off the cog belt , then start it and see if it makes the same noise . If it doesnt make the same noise , leave the cog belt off till you figure out what it is . It coud be a IC pipe rubbing on the AC pulley , no oil getting to the SC , Could be alot of things . Dont F-ck your car up wating for some one else to find the problem
Old Oct 3, 2006 | 03:05 PM
DMK's Avatar
DMK
I see some black marks where the belt is right above the blower, but when I was inspecting it, it doesn't really touch. Maybe under full load, but the sound is evident from 1k to probably redline. I've looked at the A/C belt and it doesn't appear to be touching anything. Just topped off the oil last night as well.
Old Oct 3, 2006 | 03:27 PM
booger's Avatar
booger
replied to your PM . Just because you put oil in the motor , doesnt mean that your getting oil to the blower . When you take the cog belt off and start the car , you'll know more . Report back when you do that
Old Oct 17, 2006 | 09:50 AM
Forced's Avatar
Forced
Any more news on this?
Old Oct 17, 2006 | 03:07 PM
DMK's Avatar
DMK
The jackshaft bearings went bad prematurely.
Old Sep 12, 2007 | 09:28 PM
Mr_pharmD's Avatar
Mr_pharmD
how can u tell it went bad??? does it make any noise with the cog belt off?
Old Sep 12, 2007 | 10:38 PM
DMK's Avatar
DMK
No, it should make no noise or very minimal when the cog belt is off. If the sound is still there with the cog belt off, its probably a supercharger problem. I could tell it went bad because I replaced my 3 idler pullies and the sound was still there. BeerViper on G35driver had the same problem. When I took my bearings out and I shook them, I could actually hear and feel the ***** moving around inside the bearing.
Btw, the jackshaft bearings are inside the actual shaft between the sc blower pulley(ie. the 3.33, 3.12, etc one) and the cog pulley on the backside that is not connected to the blower.
Old Sep 12, 2007 | 10:49 PM
Mr_pharmD's Avatar
Mr_pharmD
im sort of lost. Do u have a pix of what u are reffering to? Are u saying the noise wasnt from the cog pulley but the inside of the shaft that connects the cog pulley? If so, what parts will I need? I found the cog pulley from vortech but not sure the size it came with 30 or 32 tooth (http://www.vortechsuperchargers.com/...p=49&cat_key=6) but what else will I need?
Old Sep 12, 2007 | 11:22 PM
DMK's Avatar
DMK
Deleted...double post.
Old Sep 12, 2007 | 11:23 PM
DMK's Avatar
DMK
Look at the G35driver link I posted in the other Vortech noise thread by CUx....
Obadabot
Jun 18, 2023 11:31 PM
Uriyo_
Sep 8, 2021 08:46 AM
kyin
Oct 15, 2015 05:54 AM
samansharif
Sep 25, 2015 12:31 PM
