PRELIMINARY Numbers from GRD (APS ST)-431 WHP/460 tq
Originally Posted by G352NV
Yeah Ive heard that. But how can you mod a stock pump to put out that much PSI? If this can be done wouldnt someone like phunk figured it out by now?
you can send more voltage to the pump...and risk shorting it out. It's considered ok for racing, but probably not so great for a daily driver street car where the car is on for long periods of time - the pump can heat up and short out
Originally Posted by sentry65
with phunk's drag race setup and drag tires, well i dunno what zivman has, but it'd have to be something big
using whats commonly called a boost-a-pump is definatly doable. You can purchase setups that only send the additional voltage to the pumps when you need it.
while there is nothing really WRONG with doing that, it does sacrafice pump life (no big deal really since pumps are so cheap, but you dont want to get stranded). its not really anythign you would setup in a professional aftermarket fuel system, its more of a custom shop installed type deal. while i wouldnt personally run it, its not so ghetto that you would make fun of someone for having it... many electrical devices can handle additional voltage - sort of like how our stock engines can handle twice as much power as stock.
The thing is that the Z has terrible pipes feeding the rails and no return line, etc... so even if you had a boost a pump, you would still want to change all that stuff out for a kit or custom. by then, if done right, you have increased the ability to run a walbro up to power like sharif, todd, and the guys at jotech have done. sharifs car still has room to extract a TAD more fuel out of his pump IMHO if he upgraded the hardpipe and pump output.
Err anyway, once you upgrade the most restrictive part of the lines, you typically wont need a BAP (boost-a-pump), unless your truely making more power then a single pump can handle, and dont care to upgrade to twins or a larger single like the AAM stage 2.
Originally Posted by phunk
yea I dunno, I may have those, but hes got that 2nd fuel pump... maybe I should withdrawl before I get myself into trouble.
Sorry, it never was. My point was I don't want to run your system in my car. Sorry you feel that is not a wise choice, but as we have discussed, you aren't working on it and you aren't working on synth's car either.
As far as my setup goes, I am being tuned to right around 500 hp. If phunk wants to claim he's got a big d1ck because his car is faster, fine. Keep in mind he's comparing apples to oranges and with his good sense of humor keeps bringing it back to the differences only being in the fuel system. Phunk, keep patting yourself on the back about how great your car is and your fuel system is.
so in terms of safety, since most people have a single A/F gauge running off of one of the exhaust manifolds - in the case of the APS extreme kit, if one of the fuel pumps failed - say the one that runs the bank that your gauge is not on, your engine will go boom while your A/F looked just fine.
Where the other kits, if the fuel pump failed, you'd probably notice it immediately and get a A/F reading to back that up.
just a thought, I could be wrong
Originally Posted by Zivman
Keep bringing the thread back to a single vs dual pump arguement because that was my point all along
so in terms of safety, since most people have a single A/F gauge running off of one of the exhaust manifolds - in the case of the APS extreme kit, if one of the fuel pumps failed - say the one that runs the bank that your gauge is not on, your engine will go boom while your A/F looked just fine. just a thought, I could be wrong
typically its unwise to run dual independant lines to each rail like they did, but since they used a pressure balance hose.. they are pretty much back in the same boat as a car with 1 main feed line and 2 pumps.
you wont notice one pump failed until your car goes lean under high boost when it needs the flow of that second pump.
CFAUVEL
Oct 1, 2015 03:20 PM
