feul tank leak
Old Jul 11, 2007 | 12:37 PM
synth19's Avatar
synth19
that sounds like the oring, when you have 3/4 full or more, it's leaking from teh top.
Originally Posted by Abishop
yea, i have a very small leak, it just seems to come out when my gas sloshes around...
Old Jul 11, 2007 | 12:46 PM
Barzten1's Avatar
Barzten1
Mine leaks a little as well
Old Jul 11, 2007 | 12:54 PM
Abishop's Avatar
Abishop
does anyone know of a part number or O ring that doesn't expland out so easily?
Old Jul 11, 2007 | 01:26 PM
westpak's Avatar
westpak
SFZCC
It doesn't expand unless it gets wet, it is always recommended to replace it with a new when the pump is removed, I did that when I had such a leak and have had no issues.
Old Jul 11, 2007 | 07:21 PM
synth19's Avatar
synth19
OEM part number listed here, but I dont know of an alternative one:
https://my350z.com/forum/showthread....ghlight=o-ring
Old Jul 11, 2007 | 08:49 PM
Abishop's Avatar
Abishop
have you guys had further problems after the new o ring?
Old Jul 11, 2007 | 11:58 PM
synth19's Avatar
synth19
^ good question... I haven't filled the tank up since to find out! LOL!
Old Jul 12, 2007 | 06:20 AM
westpak's Avatar
westpak
SFZCC
Mine was fixed 100%, no more leaks. It is not the fault of the oring it is the fault of the installer, either he/she did not ensure the oring was in its place correctly or failed to replace it with a new one after getting wet with fuel and expanding.
Old Jul 13, 2007 | 08:09 AM
Jrooy's Avatar
Jrooy
I had the same issue after installing my APS kit. Changed the Oring and still had a gas leak when I filled up. While I was at Forged Performance getting a tune, I mentioned this to Sharif and they pulled out the gas pump to check things out. Turns out the return hose connetion was a lot of the problem. Sharif can explain better, but there is a web pattern in the plastic (underside of cap) that needs to be ground smooth to get a good seal. Sharif reworked this connection and replaced the Oring and problem fixed ... no more gas leak or smell even after topping off a full tank.
Old Jul 14, 2007 | 03:33 AM
Barzten1's Avatar
Barzten1
I replace my O-ring today and made sure everything was good to go. Gas smell is worse now. Im thinking its not the O-ring but the fuel return line instead.
Twenty4
Jan 17, 2016 01:20 PM
derekinthez
South East
Sep 28, 2015 06:35 PM
