BamBam's Update: The Boost is Loose at Forged Peformance!
Old Oct 25, 2006 | 07:37 PM
  #121
projectsherv's Avatar
projectsherv
Bambam, Congrats bro you are a very lucky man. I will have my car around the time you are picking yours up so we should all go cruising together (me, you, and alberto). My car is also at Forged as you probably know. Too bad we cant put the top down.
Sharif, awesome job you are very good at what you do.
Old Oct 26, 2006 | 12:03 AM
  #122
Sam@GTM's Avatar
Sam@GTM
GT Motorsports
Originally Posted by Sharif@Forged
Since Brent is still on a working vacation in South East Asia (yeah right), he wanted me to post an update on his car.
BamBam's engine tuning is finally done. First, I want to give a special thanks to Sam@GTMotorsports. As a new FCON tuner, I had about 100 or so questions that needed answering, and Sam really helped me to learn the ins and outs of the FCON software and hardware. If you live in the Western half of the USA, you owe it to yourself to take your car to GT Motorsports, or just stop in for a visit.
To back up a little bit, Brent's car arrived with a blown headgasket, and Chris and Devon worked for about 24 hours straight to completely disassemble and reassemble his engine engine and turbo kit. After putting it back together, we saw 5 psi oil pressure on the gauge. We tried to get BamBam back on the road, so he could attend his rally, but it never happened due to the oil issue. Actually, it turns out that we had oil pressure all along, and it was just a bad in-cabin oil pressure gauge (not a bad oil pressure sensor).
Here is a partial recap of his current setup:
Sleeved Shortblock 3.5L
JE Pistons 9.0:1 CR
Pauter Rods
GTM Stage III heads with oversized head studs
HKS Head Gasket
Rear Cylinder Cooling Modification
AAM Stage I and Stage II Fuel System
HKS FCON VPro with Knock Amp
HKS 1000cc Injectors
Greddy TT with upgraded TD06-60-1 Turbos
AAM 3 Inch Exhaust and AAM 3 inch Downpipes with Dumps
HKS EVC Boost Controller, HKS Navigator Pro
Final numbers on C18 Race fuel at 23psi
666whp Dyno Dynamics STD Correction
742whp Dyno Jet STD Correction
All 5th gear pulls, and the dyno comparo was done just a couple hours apart.
At this power level, you get basic ONE SHOT at a peak power number due to engine heat soak. On the first pass at the DynoJet, the clutched slipped for a split second near 6000rpm, and then grabbed again...causing their weird power drop. On the second run, the engine was too heat soaked and the power dropped off about 20whp. This Dyno has one tiny fan. Next time...a little heat in the clutch would have prevented that slip at the end.
The Dyno Jet down the Street:
Our in House Dyno Dynamics Dyno
brent/sharif congratulations and a job well done ,I'm always here to help ,can you imagine what you could have done with a stroker.
Old Oct 26, 2006 | 05:17 AM
  #123
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Thanks Sherv...yours is NEXT!!
Old Oct 26, 2006 | 07:50 AM
  #124
hurahn's Avatar
hurahn
Depending on your setup, the ECU might try to hunt for the idle at times. The only thing that the FCON doesn not control, is the idle. Idle speed and the DBW throttle is still controlled by the ECU.
You guys are right. The best way to describe the FCON experience, is a total OEM, and seamless powerband...just like a factory turbo car. No glitches or hickups, regardless of RPM or throttle position.
Cool then. I will refocus my resources so that I can get a FCON. I want to do some roadcourses and 1 time attack next year so I know it'll help with being smooth on that.
Old Oct 26, 2006 | 08:11 AM
  #125
BobbyRitz's Avatar
BobbyRitz
Sharif-
From a cost perspective, I'm trying to understand the differences between UTEC and FCON Pro. Price difference between the units aside, is there a difference in the amount that you charge for tuning between the two units?
I was unsure, as I know that FCON Pro allows you a greater level of control during tuning.
Thanks.
Rob
Old Oct 26, 2006 | 01:27 PM
  #126
Sharif@Forged
Forged Performance
Originally Posted by BobbyRitz
Sharif-
Thanks.
Rob
We charge $675 for UTEC tuning, and the cost for FCON tuning is $750. Our tunes are very unique. Not sure if you noticed on BamBam's dyno chart, but we made over 90 passes on the dyno, and spent a good 8 to 10 hours on the dyno fine tuning everything. Our tuning fees reflect the time, and energy we put into generating perfect and safe tunes. Some tuners might make a few passes and call it a day....not Forged Performance.
We almost always spend more time on the dyno, than we actually bill for.
Old Oct 26, 2006 | 01:31 PM
  #127
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Old Oct 26, 2006 | 02:38 PM
  #128
IIQuickSilverII's Avatar
IIQuickSilverII
so you saying 675 is for about 8 hours of tunning?.. THAT IS A DEAL!!!!!1
Old Oct 26, 2006 | 02:42 PM
  #129
BobbyRitz's Avatar
BobbyRitz
90 passes!!! That's what I call a tune. It only makes sense that tuning the FCON is more expensive.
Thanks for the response Sharif...and I concur with the above post, for 8 to 10 hours the charge is more than reasonable.
Old Oct 26, 2006 | 02:47 PM
  #130
Cannysage's Avatar
Cannysage
how will his chassis holdup on his ZR with those numbers? I don't think a traditional rollcage would allow the zr to retain the functionality.
Old Oct 26, 2006 | 03:10 PM
  #131
PumpedVA's Avatar
PumpedVA
Forged Performance = Done and Done right!
Old Oct 26, 2006 | 03:41 PM
  #132
trefling's Avatar
trefling
Yep that's true, he does not do rush job tunes on the dyno. I'm a witness to that
Old Oct 26, 2006 | 04:50 PM
  #133
Gumpdriver's Avatar
Gumpdriver
Well now we all know the secret to those outsatnding tunes that Shaif does so well. 90 passes that is crazy
Old Oct 26, 2006 | 04:52 PM
  #134
Alberto's Avatar
Alberto
Cranky FI Owner
Sharif's tuning FTW! My car ran so hard (on low boost) it blew out 3rd gear-damn you Sharif
Old Oct 26, 2006 | 05:07 PM
  #135
IIQuickSilverII
thank yourself too brotha :d
Old Oct 26, 2006 | 06:26 PM
  #136
Nismo350ZRT's Avatar
Nismo350ZRT
I think your drag racing machismo did that.
Old Oct 27, 2006 | 08:15 AM
  #137
Sharif@Forged
Forged Performance
haha...those were some funny posts. We'd rather do flat rate tuning, so neither of us are watching the clock.
Old Oct 27, 2006 | 08:38 AM
  #138
350Zzzz's Avatar
350Zzzz
Professional
Originally Posted by InjectedPerf
MIAPLAYA,
I think I am pretty close to what you have in mind.
AEBS 4.3L stroker
GT42R single turbo (hoping to fit a GT47-80 eventually)
3.5" Downpipe/Midpipe with electronic cutout (note the turndown isn't installed in the picture)
3.5" Downpipe/Midpipe....huh......please tell me more and what is it connected to?
Thanks
G
_______________________
Old Oct 27, 2006 | 08:44 AM
  #139
InjectedPerf's Avatar
InjectedPerf
Injected Performance
GT42 with a 4.3L stroker motor, 1600cc injectors, Magnetti Marelli ECU.
Thanks
G
Old Oct 27, 2006 | 10:36 AM
  #140
PumpedVA's Avatar
PumpedVA
Is this the Z you guys had at HIN DC last year?
