Assembly cost of a Short block?
Old Oct 31, 2006 | 10:42 PM
redline350ZZ's Avatar
redline350ZZ
Default Assembly cost of a Short block?
One of the options I was considering is buying parts each month Vs dumping all my coin at once. Anyone know the typical cost of assembly?? All parts provided. Also if I bought Darton mid sleeves, how much more could that be? I'm just trying to see what option would be better for me. If I did that I would send it all to one of the reputable builds on this site.
Old Oct 31, 2006 | 10:56 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
Exclamation machining costs, a few BuiltZmotors quotes
I'll be happy to provide a detailed/personalized quote for your power needs...
My recommendation:
The way that we price our motors is as follows: If you bought all of the parts yourself, and paid a local machine shop (who would probably machining this type of motor for the first time) to do the work, you would end up spending approximately $300-500 more..would have to handle all of the headaches yourself, and wait a few months- to several months
Our turnaround time on a custom built motor is now approximately 1-3 weeks, depending on the type of build
To answer your question...most machine shops charge approx.:
bore/hone: $200-300
redeck: $100-150
balance crank/micropolish: $200-300
machine block for 1/2" head studs: $500-650
redeck heads: $100-200
3 angle valve job/ clean/ rebuild/ adjust valves: $350-500
machine for half inch head studs: $100-150
assemble shortblock: $300-500
time otor: $350-500
The numbers I supplied are ranges from what I have dealt with,personally, with different machine shops in and out of the state...
We assemble our motors in house, all the machining is done locally...(accept sleeving- done at GT motorsports)
sleeving (with cost of sleeves) costs approx: $2100-2800 (depending on quality of machinery--> GTM uses a Rotler F65- the best in the industry for installing the sleeves flawlessly!)
A few BuiltZmotors quotes:
Shortblock:
and I quote:
First off, we recommend going with one of our longblock options, as we build our longblocks fully assembled with the heads torqued down to spec, the motor is timed with all timing gear installed, and the front and rear timing covers are in place. This makes the motor swap go very easily, saving you time and money having to pay to have the motor prepared for operation.
We also recommend the use of the Arias Extreme duty pistons in ALL of our builds. The piston costs more than the other forged pistons out on the market, but the strengths greatly outweigh the costs. Think of these pistons as added insurance to your builtZmotor!
Built bottom end consists of the following: Easily capable of 550 rwhp
Pistons – Arias Extreme Duty pistons 9:1 CR
Rods- Eagle
ARP main studs
rear main seal
main bearings
rod bearings
thrust washers
machine block- bore and hone (with use of torque plates)
balancing
polish crank
redeck block-(to ensure proper mating surface for heads)
clean parts- prep before assembly- clean oil channels, outer surface, etc.
“rev up” oil pump- 18% more efficient than the standard oil pump
motor assembly
Our price: $3450
+$1500 core charge (refunded when we receive your motor)
A few ways that we are different than some of the competition:
-we include ARP studs in our engine pricing (head studs with longblocks)
-we use Arias Extreme Duty pistons, good for extremely high power levels
-Our longblock package will come fully timed with front and rear timing covers installed. *(will save you time and money when swapping motors), simply pull off a few sensors and this one will be ready to drop in.
I’ll be happy to price out additional upgrades, let me know what you would like. We can omit certain upgrades to lower the costs and the price.
Call me with any questions: 505-480-1923 Todd Pickman, BuiltZMotors.com
Longblock Quote:
We recommend our longblock option, as it presents a greater savings to you. We sell all of our longblocks fully timed, with the front and rear timing covers installed, ready to go!
The following is a longblock with stock heads, feel free to inquire about any upgrades.
Pistons – Arias Extreme Duty 9:1 CR (estimated rating above 1300-1500rwhp!)
Rods- Eagle Rods
ARP hardware- Main and head studs—included (not sold extra like some other companies)
overhaul gaskets- every gasket new from Nissan
Headgaskets: stock (can upgrade)
rear main seal
main bearings
rod bearings
thrust washers
machine block (with use of torque plates)
balancing
polish crank
redeck heads and block- to ensure mating surfaces between the block and the heads are exact
oil pump- new from Nissan- recommended on a new motor build
Cams- stock
Headwork- none (can upgrade)
Valves- stock (can upgrade)
Springs- stock
motor assembly – timed, with front and rear timing cover installed
head assembly- rebuilt with new valve stem seals
Introductory price: $5100!!!
$2500 core charge (refunded when we receive your motor)
Hope that helps!
TODD
Old Nov 1, 2006 | 07:21 AM
THE TECH's Avatar
THE TECH
Sounds like a good deal. Hmmm maybe a motor build in my future...
Old Nov 1, 2006 | 08:28 AM
rocks's Avatar
rocks
Todd is doing my engine. I added up all the costs including local machine work, I could of possibly saved 1000$ if that. It wasnt worth it to me, since he has experince with the vq35de and no one local to me does.
Old Nov 1, 2006 | 11:21 AM
GTM's Avatar
GTM
Vendor - Former Vendor
Well if you are able to, I think it would be beneficial to you to save the money and purchase everything at once from the same person, these are the reasons why I beleive so:
1. Its better to have everything done by one shop, so there aren't any issues to blame on someone else.
2. Since you are purchasing all the parts from them you should get a better price since you are helping them move more volume.
3. When doing everything from one shop who has everything you save time and will be guaranteed that everything is done right.
Hope this helps your decision let me know if you have any other questions.
-George
GT Motorsports
Old Nov 1, 2006 | 12:19 PM
redline350ZZ
Thanks guys after reading your reply's it does not seem like a good idea for me to piece together a block. Im just gona hide money from wife and get a assembled long block. I did not realize all the attention that is required to properly assemble a block.
Old Nov 2, 2006 | 08:47 AM
IIQuickSilverII's Avatar
IIQuickSilverII
ahahahah i hear you... i am in the same boat
Old Nov 2, 2006 | 09:16 AM
masterj26's Avatar
masterj26
I was planning on a slow build too. But after reading this sounds like this is the way to go
Old Nov 2, 2006 | 09:26 AM
NA&CH's Avatar
NA&CH
There should be a Men only bank
I think I am going to put some twins on and then start saving for the built block. Only a matter of time.
Old Nov 2, 2006 | 11:48 AM
NoLimit's Avatar
NoLimit
Thumbs up Vakamon Motorsports
If you're still in Hawaii, ... I Highly recommend going to Vakamon Motorsports and talk to Ryan, ... tell him Sean sent you. He usually has a VQ block in stock that can be used as the 'core' for your build.
Let me know if you have any questions.
Old Nov 2, 2006 | 01:03 PM
redline350ZZ
Yea I got some friends that deal with Vakamon and theres one member on here that is dealing with sonic for a Installation of a Longblock from BuiltZmotors. I dont know if im gonna do the install here or wait till I got back to Georgia. A lot of exciting things that are gonna be released for the VQ here shortly and I'd rather wait than rush. Hardest part is deciding what my power goal is. As soon as I see the GT-K results on paper I will be able to make a more informed choice, for example to sleeve or not.
Old Nov 2, 2006 | 01:23 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
His motor should have just arrived there yesterday!!! Check out the quality of the motor, then decide!
Old Nov 2, 2006 | 04:42 PM
redline350ZZ
Oh I have no doubt the quality of your motors are great. I just need to figure out the WHP goal I'm after, and once the GT-K upgrade prices are disclosed I will be able to do that. Although 600WHP may be enough forever.
Alexreyes
Sep 30, 2015 11:30 PM
