One Sick 350Z Turbo Vid
Old Nov 5, 2006 | 05:06 PM
JETPILOT's Avatar
JETPILOT
It's a frickin REPOST!!! Some people here have seen it already so the rest of us are not allowed to enjoy it!!
JET
Old Nov 5, 2006 | 05:19 PM
1G-350Z's Avatar
1G-350Z
Originally Posted by dave079
There isnt even a VQ in that one. Check out this vid. Still has the VQ and runs an 8.3@177. The VQ I believe is pushing out more than 1500rwhp
http://www.theexperience.com/record.htm
Wrong Wrong Wrong.... It is a VQ Powered Pro Car... Worlds Fastest Nissan...
The other one is similar... The silver one ran on C-16... The Pro Car ran on Methonal...
Old Nov 5, 2006 | 05:32 PM
taurran's Avatar
taurran
Old Nov 5, 2006 | 05:37 PM
1G-350Z's Avatar
1G-350Z
A little info on the car I linked to:
The 350 relies on a beefed-up version of the mighty VQ35DE powerplant for motivation. Outfitted with JE forged pistons and Carillo rods, the 3.5L had its its rev limit raised to 8,000rpm to help keep the boost pressurized throughout the curve. A Nismo R-Tune camshaft, valve job and mild porting of the exhaust ports by Headgames are also features of this build-up.
Last year, the car was set up with two different nitrous setups – a 300 shot and 375 shot that helped the team go through two engine blocks. This season, however, reliability issues prompted them to switch over to a Power Enterprise twin turbo system, which features a PE exhaust manifold, 2.25-inch down-pipe and modified air-to-water PE intercooler. The wastegate is internal, but the HKS blow-off valve is not.
A large 75mm Accufab throttle body translates the air into additional power with high-flowing Bosch Motorsport injectors transporting loads of additional fuel from an ATL 15 gallon fuel cell. A 240gph Weldon fuel pump and Aeromotive fuel pressure regulator and filter help out with the task.
Engine management duties are performed by a MoTeC M880 system that gives control over the fuel and ignition as well as closed loop wideband oxygen control and datalogging for a number of inputs. Before Ioannou, who knows MoTeC systems like the back of his hand, came on board, the team found tuning a challenge.
“We feel we’re doing pretty good considering we’re the only ones running this V6 right now,” defended Rubio.
Drivetrain upgrades consist of a custom made Unorthodox Racing five pound aluminum flywheel that works in conjunction with a Tilton multi-plate metallic clutch and the factory 6-speed. A Nismo LSD with a Nismo finned differential cover helps distribute the power equally to the rear wheels.
Tein Flex coilovers all around provide ample adjustability for fine tweaks on race days thanks to the EDFC system. Weld 15x9-inch aluminum rims house BFGoodrich 275/50/15 drag radials on the rear axles while the fronts are 15x3.5-inch skinnies with 26x5-15 Mickey Thompson front runners. BFGoodrich came on board as a sponsor in June.
Heres a pic of the beast:
Dave
I pretty much live @ the shop.... The pic shown and the car you are discribing is pre Vinny Ten They welded the waste gates shut. and ran 10.##'s on a 6 speed. Yes a PE Kit.... Nice stuff... The car always had Motec...
Six Weeks After Vinny arrived @ PM they ran low 8's shown in one of the Videos... No offense to Head Games, but we have our own heads that we use.
Our VTR Spec motor and head programs are coming out soon... Stage I,II, and III (VTR as in Vinny Ten Racing)
PS that video never gets tired....
hulkout
Apr 28, 2017 09:00 PM
Justin100
Nov 29, 2015 03:58 PM
bcoffee20
Nov 19, 2015 06:39 PM
codek
Sep 28, 2015 03:03 AM
Twiztids4
Tuning
Sep 10, 2015 04:02 PM
