Has anyone broke 500whp with an ST?
Old Nov 5, 2006 | 11:38 AM
sugarspunZ's Avatar
sugarspunZ
Default Has anyone broke 500whp with an ST?
Has anyone broke 500whp with the stock TN or APS Turbo.
if so what mods where done to obtain those numbers?
thanks.
Old Nov 5, 2006 | 11:40 AM
sentry65's Avatar
sentry65
the burninator
don't think so, not yet anyway
I've only heard of upper 400's like around 480-485whp
Old Nov 5, 2006 | 11:47 AM
sugarspunZ's Avatar
sugarspunZ
i swear i remember reading somewhere on here that some guy was in the high 500's.
but maybe not.
Old Nov 5, 2006 | 12:05 PM
sentry65's Avatar
sentry65
the burninator
I'm all ears, but I'd think that'd get an unbelievable amount of attention from this forum - most people would have heard about it. I could be wrong though
Old Nov 5, 2006 | 12:07 PM
chimmike's Avatar
chimmike
I think it was Injected that has the custom ST kit using a monster turbo and made like 600 something
it'll just be a short while and you'll see many ST Z's over 500whp
Old Nov 5, 2006 | 12:08 PM
sentry65's Avatar
sentry65
the burninator
that dyno curve probably looks something like a supra dyno - no power until like 5000 rpms, and then it's HUGE
Old Nov 5, 2006 | 12:10 PM
chimmike's Avatar
chimmike
I don't think so, the VQ generates a good bit more torque than the 2jz
Old Nov 5, 2006 | 12:11 PM
sentry65's Avatar
sentry65
the burninator
I'm just refering to how big the turbo would have to be which means more lag, but yeah you're right
Old Nov 5, 2006 | 12:13 PM
sugarspunZ's Avatar
sugarspunZ
interesting. i though there was a few people out there. maybe i will be the first. muwahahahhaaaa.
Old Nov 5, 2006 | 12:21 PM
chimmike's Avatar
chimmike
really doesn't have to be all that big. a true 60-1 will make over 500whp. You have to remember the 60-1 in the TN kit and the GT35R in the APS kit are both smaller sized for better response, which prevents higher max power with higher boost settings
Old Nov 5, 2006 | 01:50 PM
taurran's Avatar
taurran
More like 725whp on low boost (23psi). I met Greg at SEMA and apparently he has something more in store for the car.
Whats-his-name on this forum made 500+ on his turbonetics kit with a t-66 turbocharger. The tune/powerband didn't look the best on it though. There are also some people over 500 from up north that don't post here. That's one thing that most people here don't get - most of the people that are really into building these cars could care less about the online forums and community. So sentry- don't start making ish up now...
Old Nov 5, 2006 | 01:59 PM
JETPILOT's Avatar
JETPILOT
I think I have the most powerful stock T4/60"1 Turbonetics turbo here @ 13.5psi and 456whp on 93 octane. And the powerband sucks! 500whp and the powerband would be even worse. Another turbocharger is needed. You can't do it so don't try.
JET
Old Nov 5, 2006 | 02:02 PM
chimmike's Avatar
chimmike
I don't know why you have to be told so many times, but the powerband is bad on your turbo because it's a T3 turbine housing SEVERELY restricts flow.
Old Nov 5, 2006 | 02:04 PM
JETPILOT's Avatar
JETPILOT
No sh*t...... he asked about the stock TN turbo and the stock TN turbo has a T3 housing.
JET
Old Nov 5, 2006 | 02:11 PM
sugarspunZ's Avatar
sugarspunZ
JET
exactly. anything can be done with a different turbo. i am asking about the stock TN and APS turbo.
that guy synth probably has the most APS ST power right?
Old Nov 5, 2006 | 02:24 PM
rocks's Avatar
rocks
What are the specs on the aps single turbo? like the A/R? Are they using around a .63 exhaust? Why can i never find this info....
Old Nov 5, 2006 | 02:26 PM
chimmike's Avatar
chimmike
it's a GT3582 if I remember correctly.
the 60-1 on the TN kit is slightly different because a typical 60-1 has a T4 turbine and housing while the one on the TN kit uses a stage v turbine and t3 housing
taurran's Avatar
taurran
JET
Not entirely true.
You could break 500whp with some aggressively timed cams. But why bother? You and others on here have been told repeatedly that you're trying to hammer a square peg in a round hole yet you seem to be intent on banging away at it.
JETPILOT's Avatar
JETPILOT
Nothing more can be done with the OE Turbonetics turbo included in the kit. You will need to modify the exhaust housing /turbine to make power through the full powerband.
JET
Old Nov 5, 2006 | 02:27 PM
taurran's Avatar
taurran
From what I recall they never released this exact info.
