Fuel Pressure Regulator Q's
Old Nov 13, 2006 | 07:32 PM
Cube's Avatar
Cube
Default Fuel Pressure Regulator Q's
I have a pretty hack-job Powerdyne kit on my FX35. Hack-job being that I don't agree with the fuel management.
This is the fuel management:
There's an aux pump put in parallel with the stock fuel line, and it acts to raise line pressure at preset boost levels via the FMU.
The problem is the charger belt is still spinning at low RPM or low throttle and the completely stock fuel system is then utilized.
Now my AFR gage blew and a new one is in the mail, and I have yet to get tuned so I'm taking it real easy and I'm also running a very "safe" setup on the FMU until dyno time.
Questions:
1. When I'm stopped at a light, and JUST after letting off the brake, it's "chugging" is the best I can describe it. Without an AFR gage, I don't know if it's a lean condition or super-rich. This happens ONLY when coming from a stop and not touching the throttle, and as soon as I gas it a bit everything feels smooth. Any input?
2. I figure once I get my AFR gage back in, I can tell if it's a lean condition causing this or not, and was thinking of getting around my stock fuel setup when the FMU doesn't detect boost by getting a new FPR and adjusting the pressure to allow more fuel to flow through the injectors. On an NA setup, would raising this fuel pressure at the regulator richen up the mix?
3. What are recommendations on a new FPR?
Something like this?
http://www.alteredatmosphere.com/mm5...y_Code=350Z_FS
I'd like a gage on it so I can see how steady the output is... would this be too POS and unreliable (inconsistent)?
http://cgi.ebay.com/ebaymotors/FUEL-...spagenameZWD1V
And this one not nearly as cheap, but still too cheap? Ever hear of OBX???
http://cgi.ebay.com/ebaymotors/OBX-F...spagenameZWDVW
Edit: Would TS reflash setting my idle RPM up a bit possibly correct this?
Old Nov 14, 2006 | 11:16 AM
Cube's Avatar
Cube
If this has already been covered, please point me in the right direction, thanks.
Old Nov 15, 2006 | 12:23 PM
Cube's Avatar
Cube
Nothing at all? I don't want to run an all-out AAM return fuel line because I'll obviously never need it w/ SC... so atleast any personal opinions or stories about fuel pressure regulators? Recommendations?
Old Nov 15, 2006 | 05:18 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
you're not going to be able to use any of these without introducing a return to the system
apex locator
Jul 23, 2021 02:27 AM
