Spark Plug 1 or 2 step colder
Old Dec 9, 2006 | 02:02 PM
VIZAGE's Avatar
VIZAGE
Default Spark Plug 1 or 2 step colder
What is the best to do? Should I go with 1 step colder plug or 2 step? My kit is the Turbonetics if that plays a role in the factor.
Old Dec 9, 2006 | 02:10 PM
Eazzy's Avatar
Eazzy
One step ---two is a bit cold I think---Seems Iv used LFR6AIX-11 in a NGK,
NGK has a pretty good site--chk it out
Old Dec 9, 2006 | 02:29 PM
VIZAGE's Avatar
VIZAGE
I also just found out on Sharif's website that he said that 2 step foul out quickly.
Old Dec 9, 2006 | 02:34 PM
Eazzy's Avatar
Eazzy
Ya --That quite a jump---really ---Dont take much
Old Dec 9, 2006 | 09:13 PM
overZealous1's Avatar
overZealous1
i run 2 steps colder, but for the first 2-3 seconds on a cold start it will miss. never fouled though. my next set of plugs will go back to 1 step, maybe, lol.
Old Dec 10, 2006 | 02:07 PM
q8pianist's Avatar
q8pianist
i allso had the greddy 2 step colder befor on my greddy TT kit.
after 3 days i found 2 spark plugs stop working i thing 2 step colder are good for one run.
Old Mar 24, 2007 | 09:53 AM
DanielW's Avatar
DanielW
so does running colder spark plugs actually make more power, smoother acceleration etc?
Old Mar 24, 2007 | 10:22 AM
Eazzy's Avatar
Eazzy
A hotter plug does not burn hotter, it retains heat longer.Opposite with a colder plug. Depending on the characteristics of your motor you have to plug accordingly.
If the plug is too cold, it will foul, and/or not do a complete burn. If thats the case, NO it will not run smoother or perform better.
If you are boosted, then the rule of thumb on start of the system is run a step colder to cover your ***. If after your tuned, and you have some driving time on it over the spectrum of situations and u take a plug reading, and its color is indicating RICH then step up a level.
Lots of variables
I will state again, 2 steps colder is a hell of a jump and unlikely to ever be neccessary
Old Mar 24, 2007 | 10:23 AM
350Z_LEE's Avatar
350Z_LEE
1 step colder is fine.
Old Mar 24, 2007 | 04:45 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
The 2 steppers foul out a "little" more quickly, depending on your driving habits...I should probably update our website.
We use 1 step colder almost all the time, and 2 steps colder for track use, or if I feel that customer drives their car harder than most normal people.
Old Mar 24, 2007 | 07:16 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
the better question is how do you know you actually need a colder plug? If the datalogs tell you a colder plug is needed, go for it...if you are just fitting it to fit it, I would not bother till you know IF you actually need them
As for the fouling issue, a plug that fouls too easily is simply the wrong plug for the car - regardless of its temp range. The issue the overly "cold" plugs tend to have it at idle, where if asked to idle stationary for too long, simply load up with fuel. In most instances a plug 1 step colder is all that's needed except in the most extreme of circumstances
Old Mar 24, 2007 | 07:44 PM
al v's Avatar
al v
I have the Denso iridium IKH22 ( two steps colder ,0.8mm gap ) , for more than 3 months , and I don´t have any kind of problem...........
Old Mar 24, 2007 | 07:53 PM
Eazzy's Avatar
Eazzy
Point is, Its better to go from cold to hotter, than hotter to hole in your piston
350z82
Oct 1, 2015 06:25 PM
35reilly
Sep 28, 2015 07:42 AM
