Some Accesories for the TN kit....
Old Dec 11, 2006 | 11:50 PM
JETPILOT's Avatar
JETPILOT
Default Some Accesories for the TN kit....
I have come across a few parts that Turbonetics owners might find come in handy.
3/8 NPT plug to cap off the oil return hole in the upper oil pan to put in an oil pan spacer return or to block it off when removing the kit. Sumitt part# SUM-G1487B-1
You can use this -10AN 3/8 NPT 45 degree swivel for an upper pan oil return fitting. Sumitt part# EAR-824511ERL Get some 10AN oil safe heat resistant braided line to use as an oil return line.
Use this 3/8 -10AN fitting for the turbo oil return fitting. Sumitt part# EAR-982311ERL
JET
Old Dec 12, 2006 | 12:44 AM
taurran's Avatar
taurran
Nice info. Thanks for the parts/numbers.
Old Dec 12, 2006 | 03:23 AM
chimmike's Avatar
chimmike
if that last fitting is aluminum, I'd be wary of using it in on the turbo itself....I like using brass fittings there or steel due to the heat that cast iron gets.
thanks for the part numbrahs!
Old Dec 12, 2006 | 06:45 AM
MIAPLAYA's Avatar
MIAPLAYA
Werd...the turbo oil drain fitting should be brass. I wouldn't use aluminum there either...
Old Dec 12, 2006 | 12:29 PM
JETPILOT's Avatar
JETPILOT
17,000 mi and no issues withe the aluminum elbow. AAM uses this part on all of there Turbonetics oil spacer kits.
JET
Lightning Guy
Jul 5, 2016 06:25 PM
hbenet
Mar 3, 2005 01:22 PM
ares
Nov 21, 2002 03:03 PM
