Went into Safe Mode
Old Dec 22, 2006 | 11:18 AM
AmateuRN's Avatar
AmateuRN
Default Went into Safe Mode
Had check engine light come on that was for Crankshaft Position Signal. Cleared it with an OBDII code reader and when I started the car back up it went into a safe mode.
It would only go to 4th gear - its an automatic and the Manual Mode did nothing.
Each shift was very hard.
The fans stayed on all the time.
I had NO tachometer and the SLIP / VDC lights were on.
I didn't get on it and babied it [40mph max] on the way home. It idles fine and runs OK other then the shifts. I unplugged the battery to try and reset everything.
HELP! Will it be OK once the battery is plugged back up or did I **** it up. My tuner is 200 miles away and they are closed for the holidays...
Old Dec 23, 2006 | 02:42 PM
AmateuRN's Avatar
AmateuRN
I went out to start it today and it started just fine. No CEL or anything I could tell while idling. I haven't gotten to drive it, so I'll go do that shortly. But all the gauges work and no fans came on... so I assume, at this point, its out of safe mode.
Old Dec 23, 2006 | 02:56 PM
Sean's Avatar
Sean
glad you don't have to worry about it for the hollidays.....
Old Dec 23, 2006 | 03:00 PM
AmateuRN's Avatar
AmateuRN
One of the codes was for Crankshaft Position Signal - since it is intermittent and comes and goes, should I replace that? I thought I read awhile back that other people were having problems with that sensor and there was a little mod you could do yourself to stop it.
The other code was for catalytic converter... teeheheh.
Old Dec 23, 2006 | 03:10 PM
MIAPLAYA's Avatar
MIAPLAYA
Look at the wiring from your CPS. A local guy had his get melted by the long tube headers he had and it would randomly throw the code and drive like crap.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
bcoffee20
Nov 19, 2015 06:39 PM
FromGtoZ
Sep 20, 2015 03:41 PM
