Check Engine Light With F-con
Old Mar 3, 2007 | 07:50 PM
  #41
G3po's Avatar
G3po
Originally Posted by Sam@GTM
This did not just happen over night I believe I've spent over 40 hours chasing this issue. a lot of it is really to utilize what the F Con as engine management can do. If you can make the ECU stay in open loop mode, the ECU will never self check it self and set any codes.
So to answer your questions. A combination of tunning and flashing the ECU (GTM Spec Flash). Something to share, we have some cars getting tested at a referee smog station and the car DID pass the smog inspection on the F Con.
This is by no means an easy task and is VERY time consuming, So I can see why most tuners would not do it.
sam
I'm curious, have the cars tested at the referee been stock cams, bore and stroke and NA? I wonder if ,for example on a 4.2L (ie. 10:1 SCR) NA + JWT S1 cams, ~440cc injectors scaled by Fcon , if it could pass? And of course OEM CATs in place.
Old Mar 3, 2007 | 08:34 PM
  #42
Sam@GTM's Avatar
Sam@GTM
GT Motorsports
Originally Posted by accordfreak
so the cobb turns the cel off completely for all codes? If so, what if there's a real problem that comes up? Would it be possible to just turn off that one code that goes off all the time instead of all of them?
1) the cobb unit is not out yet
What we are talking about has nothing to do with cobb at all. We are not disabling the physical cel function of the factory ecu. If there is a problem the CEL will turn on. What we are doing is tuning the car as close to OEM as possible and fooling the factory ecu to stay in open loop as long as possible so it does not trigger a CEL.
sam
Old Mar 3, 2007 | 08:36 PM
  #43
Sam@GTM's Avatar
Sam@GTM
GT Motorsports
With the NA 4.2L strokerr, mild cams, and 440cc injectors, with the fcon we are able to make the vehicle pass CA emmisions standards, I am very confident since I was a smog/driveability technician for over 8 years.
sam
Old Mar 3, 2007 | 09:03 PM
  #44
G3po's Avatar
G3po
sam
Thanx. If it were the same setup but with 9:1 SCR and 650cc, do you think it could be made to pass? For example for use with Vortech?
Old Mar 3, 2007 | 09:13 PM
  #45
Sam@GTM's Avatar
Sam@GTM
GT Motorsports
We just did last week on a car that had one of our stage 2 long blocks with our cams, vortech super charger with fuel return system 560 denso injectors .the guy got pulled over for modified EXHAUST .so he had to go to the referee smog station to get the ticket signed off .made a smog tune for him , still made 425 WHP with cats and did pass no problem .
Sam
Old Mar 17, 2007 | 06:14 AM
  #46
CESAROTORRES's Avatar
CESAROTORRES
Default FCON and Check Engine
Hello every one,
Please do not tell me that after we spent 3,000++++ on FCON pro and other parts, I will have to live with these annoyances
Cesar
Old Mar 17, 2007 | 06:26 AM
  #47
Jay'Z's Avatar
Jay'Z
Originally Posted by CESAROTORRES
Hello every one,
Cesar
Yes, you did........... I was just at Uprev, and after consulting with them.. Im going with their solution.. They can tune the ecu..... So no piggy back for me......... Thank god!! Ill keep ya posted.. Ill be selling the utec!
Old Mar 17, 2007 | 07:03 AM
  #48
CESAROTORRES
Default No Piggy Back!
Do you mean only the OEM ECU?
Thx
Cesar
Old Mar 17, 2007 | 07:08 AM
  #49
Jay'Z's Avatar
Jay'Z
Thx
Cesar
Exactly.. Ill let you know how it turns out first..... Uprev can save as much as 5 maps on the factory ECU.. Its basically the best way to go.... IMO..
Old Mar 17, 2007 | 08:12 AM
  #50
Zivman's Avatar
Zivman
The resolution for something like the FCON is much better for a FI application, not to mention eliminating the maf. If our ECU could see boost, I would agree that manipulation of the factory ECU would probably be best. For this application, the control and resolution the Fcon has puts it heads above the factory ECU when you add boost into the equation
Old Mar 17, 2007 | 10:47 AM
  #51
BrianLG35C's Avatar
BrianLG35C
Do you still have CELs?
Old Mar 17, 2007 | 06:04 PM
  #52
Zivman's Avatar
Zivman
I have CEL with my setup. I get 2 o2 sensor codes related code.
I know it is less than Ideal, but the CEL means absolutely nothing and I have grown to ignore it
Old Mar 17, 2007 | 06:39 PM
  #53
Nitrouz's Avatar
Nitrouz
Back to Z
+1
Old Mar 18, 2007 | 08:37 AM
  #54
BrianLG35C's Avatar
BrianLG35C
Originally Posted by Nitrouz
+1
So you haven't had the Sam/GTM reflash/tune to eliminate it?
Old May 2, 2007 | 08:59 AM
  #55
Gman2004's Avatar
Gman2004
Ok so after having the FCON for over 1 year and my check engine light on it's now turned off. It has turned back on, but then other times I'll start the car and it's off. I have not made any changes on the car. Weird! Does the check engine light burn out if it stays on for a long time?
Old May 2, 2007 | 09:22 AM
  #56
ML2000's Avatar
ML2000
Gman2004, i have a problem with my check engine light going off and then on and I am still NA. Hopefully when I get my FCON (I will be going FI down the road) install in Dec. it will stop, but if not it's ok.
Matt
Old May 2, 2007 | 09:27 AM
  #57
Gman2004's Avatar
Gman2004
yeah I learned to live with my light. In fact I've owned my car for 3 years now and my light turned on when I switched my exhaust and added tp's which was about 1 month after I bought the car. It was just weird that after being lit for a year straight it decides to shut off.
Old May 2, 2007 | 09:53 AM
  #58
phunk's Avatar
phunk
CJ Motorsports
Gman2004: I wouldnt worry about it, its 99% most likely just your ECU not likely the A/F ratios its seeing during its closed loop while the FCON is doing its own thing.
Old May 16, 2007 | 03:14 PM
  #59
G35cTT's Avatar
G35cTT
I swear I get these problems after the fact, anyways I get a code 1168 bank 2 error. So are you guys saying replacing the o2 will not fix this? You think there might be a slight chance the sensor is burnt out? I just replaced pulleys on my car and it was working ok but then a few days after this code came up. I cleared it drove around no code, then next day cruising around CEL. When this light comes on it feels like my car goes slower but I may be wrong.
Old May 16, 2007 | 05:00 PM
  #60
Zivman's Avatar
Zivman
You're o2 sensors are basically doing nothing now. You are running of the fcon sensors - density. wouldn't matter if it was burnt out since it doesn't have any affect on the way your car is running
