Check Engine Light With F-con
Old Dec 25, 2006 | 05:36 AM
ktown z's Avatar
ktown z
Default Check Engine Light With F-con
I always get the check engine light when I WOT in a low rpm with the FCON tuning. When I clear the code it reads bank 1 running rich. The question is can I put a check engine eliminator between my exhaust and o2 sensor? I am talking about the extension o2 bung found on the internet.
Old Dec 25, 2006 | 06:44 AM
Zivman's Avatar
Zivman
I get the code now and again. It means nothing as the 02 sensors are not used for fueling. You could completely remove the sensor and it would have no affect. that said, I don't think a nonfouler would have any impact on getting rid of the light.
Old Dec 25, 2006 | 06:49 AM
Gman2004's Avatar
Gman2004
+1. I have the non-foulers and still get that code. My light is almost always on. I don't even bother clearing it anymore. It's weird though cause sometimes I'll start the car and have no SES.
Old Dec 25, 2006 | 07:15 AM
Sam@GTM's Avatar
Sam@GTM
GT Motorsports
Since the factory Ecu has no control over fuel and timing ,it keeps trying to make corrections to the fuel trim and when it does not see the desired changes according to its correction its flagged the service engine soon light accordingly, I had managed to make the Ecu stay in open loop at idle and build a fuel map very close to what the factory Ecu like to see in vacuum witch made the car drivability and idle beyond perfect and the service engine soon light did not come on for weeks, but not permanently. steel trying .
Old Dec 25, 2006 | 07:54 AM
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
Mine comes on also but stay on. Sharif will clear it and it will be good for a week and then it comes back on??
Old Dec 25, 2006 | 08:56 AM
phunk's Avatar
phunk
CJ Motorsports
mine comes and goes, i have an 03. I assume the factory wideband cars have it much worse then mine.
if there is enough demand for a solution, i have a friend who builds calibrated primary O2 eliminators that are intended for precisely this situation. he developed them for turbo vipers we were building at work since we would keep the stock ECU in with the Motec just like this with the FCON.
i can get us sims that would emulate all 4 o2 sensors under perfect conditions. how successful this technique would be, depends on how intelligent the ECUs circuit detection is... specifically during cold start and stuff when it might find it wierd to get a perfectly clean o2 reading. but its worked fine in other cars so it should be good.
Old Dec 25, 2006 | 09:35 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Yup, Sam is correct. Trying to keep that CEL from coming on is super tricky. Even the slightest changes in AF ratio at idle, part throttle, and cruise, can cause the CEL to come on...as the ECU is trying to correct fuel...but has no control over fuel. Since the stock ECU has no control over fuel trims, it's darn near impossible to prevent that light from coming on.
Regardless, the cars run great, and I just ignore the CEL.
Old Dec 25, 2006 | 10:13 AM
gringott's Avatar
gringott
Does UTEC not have this problem because the ECU controls at startup and idle?
Old Dec 25, 2006 | 10:19 AM
Sam@GTM's Avatar
Sam@GTM
GT Motorsports
The reason why the uteck does not have this problem ,because it oprates as a piggyback in closed loop and act like a standalone in open loop operations,witch the factory Ecu is not looking at the fuel trim any more at that stage .
Old Dec 25, 2006 | 10:20 AM
gringott's Avatar
gringott
Thank you.
Old Dec 25, 2006 | 10:23 AM
BoOsTedz33TT's Avatar
BoOsTedz33TT
when mine does it, i just retune the car, it goes off once a year when the seasons change. All we did was some datalogging, and did a street tune
Old Dec 25, 2006 | 10:50 AM
ML2000's Avatar
ML2000
If your friend is able to makes one that works, please put me on the list.
Old Dec 25, 2006 | 03:52 PM
mrtomcat's Avatar
mrtomcat
That would be awesome. I hate having that stupid light on and am worried that I would miss a real issue because I think it's the rich code...
On top of it it's embarrsing when you're trying to show off your car and there's a check engine light running...doesn't matter how fast the car goes first reaction is always: Dude, why do you have a cel? anything wrong with the car?
Old Dec 25, 2006 | 05:13 PM
ktown z's Avatar
ktown z
Since the FCON controls the A/F ratio do I still need the maf sensor? I don't know much about tuning but I have seen photos on the net of Z's with the FCON and it looks like no MAF sensor.
Old Dec 25, 2006 | 05:21 PM
phunk's Avatar
phunk
CJ Motorsports
you can take out the MAF. the FCON has a voltage output that is used to emulate its existence to keep the stock ECU happy. So even if its still in there, its not even doing anything, its signals have been completely bypassed.
Old Dec 25, 2006 | 07:15 PM
meatbag's Avatar
meatbag
I had planned on just covering up the CEL with some tape.
Old Dec 25, 2006 | 10:53 PM
Sam@GTM's Avatar
Sam@GTM
GT Motorsports
I think the ultemate solution is going to be the flash program form cobb ,witch will allow you to turn off any check engine light permanently ,this is going to be the only solution as it has been proven in the Subaru platform
Old Dec 25, 2006 | 11:23 PM
Cannysage's Avatar
Cannysage
you have a pm.
Old Dec 26, 2006 | 09:26 AM
phunk's Avatar
phunk
CJ Motorsports
Does this also keep the code from being stored in the ECU so that people can pass emissions diagnostic tests?
Old Dec 26, 2006 | 09:35 AM
Philthy's Avatar
Philthy
Boost Junkie
I run the Cobb system in my Subi, and once you turn off the code, the ECU just ignores any errors... It doesn't trigger the check engine light or flag any codes... I've had my dealer run their scan tool and nothing shows up...
