Check Engine Light With F-con
Old May 16, 2007 | 05:47 PM
  #61
G35cTT's Avatar
G35cTT
Originally Posted by Zivman
You're o2 sensors are basically doing nothing now. You are running of the fcon sensors - density. wouldn't matter if it was burnt out since it doesn't have any affect on the way your car is running
OK, but I should replace it if it's burnt right?
Old May 16, 2007 | 05:58 PM
  #62
Gman2004's Avatar
Gman2004
Which O2's sensors are you refering to? The set closest to the manifolds or the ones on the tp's? Either way they aren't doing anything. I think mine are bad as well, but I am not changing them. It's a waste of money cause it won't change anything. After 1 year with the FCON my CEL light has turned off. I don't know what happened, but it's not there anymore.
Old May 16, 2007 | 06:16 PM
  #63
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
I bet the bulb burned out. If only we could all be so lucky.
Old May 16, 2007 | 09:16 PM
  #64
G35cTT's Avatar
G35cTT
The ones on the down pipe adapter not on the cats. I thought my car was cursed until I seen alot of you guys have the same problem.
Old May 17, 2007 | 03:45 AM
  #65
Zivman's Avatar
Zivman
it isn't a problem
Old Jul 10, 2007 | 03:06 PM
  #66
G35cTT's Avatar
G35cTT
Even though I was told it wouldn't help I got a new 02 that goes on my downpipe since it was throwing that 1168 code swapped it out w/ the new one the old one looked OK but must of been something wrong with it. I now have no check engine light.
Old Jul 11, 2007 | 05:11 AM
  #67
MR RIZK's Avatar
MR RIZK
FCON installed and tuned with HKS ST no CEL
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
