out of the box...zero tuning...and safer... ???
Originally Posted by Oleg
Actually I do own a Z. I finally test drove a GTO and was not as overwhelmed as I was by reading the specs in magazine. Too heavy, too much body roll, I didn't like the brakes (I have Brembo GT on my Z), etc.
Anyway, I kept the Z. This spring I am getting a valve body upgrade and a set of Greddy coilovers. After that, who knows...
And as I said, I am very much prepared finacially for a blown motor scenario and will not bother with any of the ST kits.
I don't realyl care to argue the APS vs Turbonetics thing. I'm surprised people like zivman still do.
Originally Posted by taurran
I don't think the exhaust has anything to do with most people's tapering boost issues, but that's just me...
From my own experience I had about a 0.5-1 psi drop at most with my fabricated greddy exhaust and that was the first one GRD did before the boost drop issue was even known.
Originally Posted by MIAPLAYA
Proper EMS? A 15 year old Unichip with DOS based tuning software? The fuel system is adequate at best. The dump pipe? Which pipe is that? The only thing Turbonetics "dumps" is the BOV to the atmosphere. APS design is superior? Turbo at the bottom of the car where even APS owners admit they scrape the housings on speed bumps. Boost drop unless you use their exhaust, faulty check valves, half@ss wastegate system unless you buy at an added cost their external wastegate pipes AND a Tial wastegate. Subpar customer service, an abysmal warranty system, do we need to go on?
Originally Posted by Zivman
I agree I would run the TT setup vs the single, but to say that because you wouldn't want to run a proper FI designed exhaust is just comical to me. You wouldn't want to buy a properly designed exhaust, but see no issue running a joke of reflash, no fuel return, having to tap your oil return, or running a space limited dump pipe due to, what I consider poor, design???
keyword: out of the box
Originally Posted by doug
out of the box to me means out of the box... not buying other stuff like actuators and exhaust to make my kit perform properly out of the box..
As far as I am concerned the only positives about the TN kit are the customer service and the price point. That said, when you see what is included for that price point, it is clear it is no bargain when the APS setup offers SOOO much more for a marginal increase in price
Originally Posted by redline350ZZ
I would never be happy with just what is sold in any F/I kit. They should all be renamed starter kits to avoid confusion.
If that's the case, one man's "starter kit" is another man's complete setup
you go on promoting your customer service and I will go on promoting the better kit.
Then after all that try to get replacement parts is a joke!!After accident good luck replacing IC and charge pipe. I have a better chance seeing God. Glad to be rid of APS and I even grinding APS off my plenum. Classic comment with Peter after all the BS I went trhough "well thats just bad luck mate"
Originally Posted by wtf no turbo
I think they both suck!!!!! LOL to be serious nothing will be right with me and aps. That check valve problem to me was unexcusable. You spend 5500 bucks plus exhaust to be r&d? I would have never made the trip to GRD and probly would still have my stock block running 10psi on AAMs tune. With there awful CS and the high and mighty attitude the conduct the CS with made me drive 800 miles to find a POS checkvalve as the problem.
You are all ****ing pathetic, go drive your cars.
To the OP: Go ride in an ST, TT, and SC, then make your choice, they all have their pros and cons.
In my opinion:
If you want maximum performance and plan on building the motor later on. go with a TT kit.
If you the most reliable and controllable setup, and are ok with a maximum possible output of around 450whp, go with an SC.
If you want a good intermediate between maximum power and reliability, go with the ST.
In my opinion:
In my opinion:
In my opinion:
you my friend in all your rage have digressed from the original question..
the original question is.. what setup is good for an install in your home garage and run out of the box without tuning...
In my opinion:
In my opinion:
wow ! do not get into the APS vs TN confrontation ! please !
boths great kits with great potentials !
and for your information, actually, you can found here... the TN ST stage 1 and the cokmplete APS ST kit FOR THE SAME PRICE !!!! 5000$ !!!!! This is a fact !
and when you add UTEC to the TN and APS ST exhaust to the APS, YOU STILL AT THE SAME PRICE !!!! still a fact !
BUT !
even after a UTEC or the APS ST exhaust, when you take a look on both part list and some dyno plots... it seem to me that you have a more complete kit with the APS than TN... BUT this is only my opinion... and this is why I will go this way... for the moment... until my search for new facts and feedbacks is over...
BUT !
OP, correct me if I am wrong, but the purpose of this thread for you was to figure out which FI kit can be done in garage, on jackstands, by yourself, yes?
In that case you should be looking not at the so-called "out-of-box completeness", but for the ease and simplicity of installation of the supporting mods. For example, if you can install an ST kit, an exhaust should be a piece of cake for you, etc...
This thread is dumb and needs to be closed. Thanks...
Hey ! there is very good posts in this thread with good info... if you don't like it, simply don't read ! and go on others threads...no ?
Don't mind him. He's just pissed that you're leaning towards APS and not the TN...
I highly doubt that 90% of the time that would ever be considered true. A lot of people take Z modding very seriously and feel that no one should be permitted to do something as extensive as F/I without the proper knowledge. Maybe we should generate a Forced Induction Test and you need to score a 80 or above to Boost
