Turbo or Super Charged? Pros and Cons of both
Old Jan 10, 2007 | 11:01 AM
  #141
doug's Avatar
doug
Originally Posted by idwin
why dont you guys pm each other instead of thrashing this guys thread?
its for the next guy who is about to make another thread about Turbo's or Superchargers? Pros and Cons of both who might actually use the search function
Old Jan 10, 2007 | 11:03 AM
  #142
ARMSTRONGARMS's Avatar
ARMSTRONGARMS
you guys need a room, you fight like youve been married 40 years
Old Jan 10, 2007 | 11:05 AM
  #143
dutchboy's Avatar
dutchboy
Originally Posted by sentry65
because your turbos are fully spooled
my vortech is only half spooled
That sounds like lag.
Old Jan 10, 2007 | 11:06 AM
  #144
sentry65's Avatar
sentry65
the burninator
your definition of "lag" is incorrect. You're thinking of turbo spool
look it up or read the two posts where I define it and include a link to what "lag" really is
jeez am I a broken record or do people just not read?
Old Jan 10, 2007 | 11:11 AM
  #145
dutchboy's Avatar
dutchboy
sentry, easy man. I know what lag is, just busting your ***** for the way your post read.
Old Jan 10, 2007 | 11:15 AM
  #146
sentry65's Avatar
sentry65
the burninator
Old Jan 10, 2007 | 11:23 AM
  #147
skidmarq's Avatar
skidmarq
No, let them continue, this makes for educational reading material...
Old Jan 10, 2007 | 11:46 AM
  #148
priscilla ls1's Avatar
priscilla ls1
Originally Posted by Fishey
This thread for the win.
I love how you compare two systems like supercharging/turbo charging based only on the kits that are available for your application. Its sad but when people who consider themselves "Tuners" argue based on pre-made kits I find it funny. The theory behind both Centrifugal -superchargers and turbos is well documented but no one on here has even mentioned the biggest limiting factor of the supercharger setup for the 350Z. Its the only factor that says turbo > supercharger as far as power is concerned on the VQ motor. That being said the current power of superchargers on 350Z's is weak and they could go alot higher but they will never beat a proper turbo setup (Single or twin) for overall power.
P.S.
Doug said a turbo has less lag then a supercharger and because of that he should be removed from this discussion as well as anyone else that agrees with him. Why? Simple, he posted dyno graphs and anyone who has actually driven a car at a real racetrack *Mid-Ohio, Miller Park, VIR, Etc* can tell you that has nothing to do with lag. When people talk about "turbo lag" its often throttle response before you get power and in a turbo car you have to re-spool the turbo in order to get boost again. Do you think superchargers have to re-spool? No, they run of a belt so as soon as you hit the gas your back into the power. This makes a huge diffrence on a racetrack and even more in AutoX. So please if you are going to post such non-sense please understand physics before posting.
Thanks your friend
-Fishey.
+1
Best post thus far.
Turbo is great for a strait line but you get lag inbetween shifts and if you are cornering. I say if I am at WOT hitting 13psi and take my foot of the gas and my psi drops down to 0psi it will take me about 2 seconds to get back up to my 13psi that I was at (this is called LAG!), where as you are SC you are at your peak psi the moment you hit the gas at WOT.
Old Jan 10, 2007 | 11:49 AM
  #149
sentry65's Avatar
sentry65
the burninator
Originally Posted by priscilla ls1
+1
Best post thus far.
+1!
only the exception to that last part would be centrifugal SC's PSI wouldn't be at their peak psi unless you hit the gas at WOT at redline which you don't since that's when you shift
Old Jan 10, 2007 | 11:51 AM
  #150
dutchboy's Avatar
dutchboy
Except with a centrifugal you would be waiting until redline for peak psi.
Old Jan 10, 2007 | 11:52 AM
  #151
dutchboy's Avatar
dutchboy
Dammit sentry!!!!!
Old Jan 10, 2007 | 11:54 AM
  #152
Alberto's Avatar
Alberto
Cranky FI Owner
+1
Best post thus far.
Speak for yourself...and to further clarify a Roots S/C would immediately be full boost after a shift, if its a Vortech like Sentry's and he lands a 1-2 shift at 4500rpm's he'd only be at a weaksauce 4-5psi-hardly full boost.
Old Jan 10, 2007 | 11:55 AM
  #153
sentry65's Avatar
sentry65
the burninator
Dammit sentry!!!!!
sorry beat ya to it
Old Jan 10, 2007 | 12:00 PM
  #154
Kf3's Avatar
Kf3
I'm getting lots of info. Guys keep going
Question. I thought the purpose of a TT setup was eliminate turbo lag? I thought the lag was only an issue in single turbo setups.
-KunFigur3
Old Jan 10, 2007 | 12:03 PM
  #155
sentry65's Avatar
sentry65
the burninator
actually I'm at 8 psi at 4500 rpms
but don't forget the 3.9 final drive I'm running
otherwise that's just the 1-2 shift. The 2-3, 3-4, and 5-6 shift all progressively put you higher into the rpms compared to the previous shift
so 2-3 shift would be closer to 4900 rpms at the start of 3rd gear
and we all know how long you spend at 4000-5000 rpms anyway once you shift
besides, even a ST will have more tq at 4500 than a TT
....oh that lovely brief bubble of lovely ST torque that people spend so much time in when going WOT to redline - just teasing man, I know - point taken
Old Jan 10, 2007 | 12:17 PM
  #156
sentry65's Avatar
sentry65
the burninator
-KunFigur3
TT's do have less lag because they're two smaller turbos which physically can react faster and each don't need as much exhaust gas to spool up. Lag will never fully be eliminated on a turbo setup despite it being reduced to almost nothing to where it's not a big deal
on top of that, they also spool up earlier in the rpm range
usually PSI vs PSI against a ST, the twins usually put out less midrange tq between 3500-4500 rpms than a ST.
Old Jan 10, 2007 | 12:18 PM
  #157
priscilla ls1
Anyways I was talking about the roots type, I was thinking about your situation their also Alberto I know you do the power shift thing and keep your foot planted the whole time. And the vortech like sentrys makes less backpressure and is at 2psi and climing with out a load he makes psi at idol.
Old Jan 10, 2007 | 12:22 PM
  #158
sentry65's Avatar
sentry65
the burninator
no I have more backpressure at idle than the big turbo setups with huge exhausts and test pipes But yeah just off of Idle I already have some boost coming out of the vortech - not a huge deal though, but it's there. A lot of TT setups can start making some boost as early as 2000 rpms though - possibly even 1800 rpms in some cases.
It's a trade off though. Usually the turbo setups making gigantic numbers with bigger turbos and huge exhausts take longer to spool up the turbos than say a kit like the JWT kit which has tiny turbos
Old Jan 10, 2007 | 12:25 PM
  #159
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Lag to me and most of the boosted public is the time when you go full throttle until you hit full boost or full spool (call it what you want). For me it's about a 1/2 of a second or less(as long as I'm above 2500rpms).....for you it's waiting for your tach to near redline. So in the true sense of the word lag (which I think is a bad way to label and centri-SC) you have more of it. Although I wouldn't call it lag in your case...I'd call it a linear boost curve....which is nothing like a turbo's boost curve.
Please go run your car so we can see what it will do.
Old Jan 10, 2007 | 12:28 PM
  #160
Alberto's Avatar
Alberto
Cranky FI Owner
Sentry are you saying your car at idle isnt in vacuum but making a little boost?
