Stock Vortech Blow Stock Motor?
Old Jan 11, 2007 | 09:36 PM
dave3529's Avatar
dave3529
Question Stock Vortech Blow Stock Motor?
Hey, just wondering because everyone says that the vortech is one of the safest forms of f.i. has anyone even heard of anyone ever blowing the stock motor with only the 3.33 pulley and a tune? (aka the stock vortech kit wit a proper tune)
Old Jan 11, 2007 | 10:47 PM
sentry65's Avatar
sentry65
the burninator
you mean blowing it up with a big hole in the block and broken rods everywhere?
not many have done that
Old Jan 12, 2007 | 10:18 AM
dave3529's Avatar
dave3529
ya, i mean snapping rods. if i had the stock vortech kit and had it tuned and made 330whp to 350whp i would be more than happy but i don't want to snap any rods so i'm wondering if anyone else has snap or bent a rod with 350whp or under with the 3.33 pulley.
Old Jan 12, 2007 | 10:20 AM
THE TECH's Avatar
THE TECH
Vortech continues to be one of the safest for the Z.
Old Jan 12, 2007 | 10:54 AM
sentry65's Avatar
sentry65
the burninator
I'd actually really like to know about anyone who actually has broken rods and blew up the block because I'm honestly not able to think of anyone who that's happened to, but wouldn't doubt at all that it's happened to at least a couple people
From everyone I've read about and also talked with who hurt their engine with a vortech has almost never been a catastrophic failure. A lot of the people who hurt the engine knew they were running lean on their A/F gauge, or thought they heard some detonation, but continued to push the car anyway - so there were some warning signs.
they've usually chipped a piston ringland which is bad, but not a catastrophic failure. It usually means they lose some power, engine might make some new rattling sounds, might burn more oil since more oil might be able to slip past the piston, might have some smoke come out the exhaust, etc. Kinda depends just how bad it is. The inside of the cylinder chamber can get all scratched up, a valve might get slighly bent from the debris hitting it. The engine will still operate with those issues though.
Most people that have hurt their engine ended up building up the engine anyway because it's no fun driving around making less power or lots of black smoke coming out the exhaust, but they at least are able to drive it around until they get the money together for an engine build
330-350whp is very unlikely to damage the engine - assuming you have a decent tune of course. I don't think 330-350whp on a vortech setup is very dangerous at all since it only stresses the engine in the higher rpms when you go WOT and those are fairly conservative peak numbers for any sort of FI setup anyway
Old Jan 12, 2007 | 10:56 AM
617G's Avatar
617G
search member kzanard
Old Jan 12, 2007 | 01:04 PM
booger's Avatar
booger
I broke a ringland at the track running about 350whp . Not enough timing being pulled . There were no signs of knock or detonation at all . I really dont think you can hear it happening with out some type of ad while on the dyno .
The piece broke off and got lodged in a valve a bent it
Old Jan 12, 2007 | 01:46 PM
ANXIOUZ's Avatar
ANXIOUZ
350whp seems really conservative for a Vortech. With a good install and good tune, you'll be just fine. Bad install or bad tune and who knows.
Old Jan 12, 2007 | 02:44 PM
booger's Avatar
booger
You'll see 350whp to 375whp on a 3.12 pulley depending on the dyno , some claim as high as 430whp ...like I said dyno's very greatly . If you leave the stock tune in , the timing is safe .
Old Jan 12, 2007 | 06:15 PM
dave3529's Avatar
dave3529
booger, the stock tune is safer then getting it tuned?
Old Jan 12, 2007 | 07:06 PM
booger's Avatar
booger
lets just say it isnt going to be blowing ringlands or motors . Its normally a very rich A/F and plenty of timing being pulled to be safe . It just wouldnt be a very good tune
Old Jan 13, 2007 | 01:12 AM
dave3529's Avatar
dave3529
well after searching even more and finding there to be deffetive ss boxs i'm really up in the air now. is there signs of the box being bad and time to get it fixed befor the big boom or no sign? it sounded to me from kzanard's experince that he had a lot of signs but just took to long to figure out that it was the ss box. but if it was fixed before so much time and miles went by it should have been fine correct?
Old Jan 13, 2007 | 04:34 AM
booger's Avatar
booger
Defective SS boxes ???? Ive never heard of one . And if you ran across a thread about one being bad . You will run into just as many threads about defective Utec EMU's also . Your getting paranoid
Old Jan 13, 2007 | 01:13 PM
VIZAGE's Avatar
VIZAGE
Safer: yes Weak: yes
Old Jan 13, 2007 | 01:27 PM
booger's Avatar
booger
F/I and worrying about blowing your motor ....dont go together . Stop being paranoid and do it . Or go back to modding your car with grounding kits and intake tubes
Old Jan 13, 2007 | 04:35 PM
THE TECH's Avatar
THE TECH
This is coming from someone who has an SSV. LOL!
Old Jan 13, 2007 | 04:54 PM
VIZAGE's Avatar
VIZAGE
That's true.
Old Jan 13, 2007 | 06:46 PM
sentry65's Avatar
sentry65
the burninator
I probably have the weakest setup of all then since I have a vortech and SSV
Old Jan 14, 2007 | 08:54 AM
dimebagdolf's Avatar
dimebagdolf
That SSV sure sounds awesome!
Doesn't it add like 50 whp???
Old Jan 14, 2007 | 06:44 PM
350zx6r's Avatar
350zx6r
how does it work with a 2006 z as far as tunning or compatibility?
