Some problems with APS TT !!!
Old Jan 14, 2007 | 09:12 AM
Dubai's Avatar
Dubai
Default Some problems with APS TT !!!
While driving my car I noticed the following;
1. the APS overflow coolant tank is spitting coolant when driving the car hard. and when I park the car for like 3 hour I find the tank empty!
2. there is a slight white smoke coming from the exhaust when shifting at low and mid range rpms. I couldnt notice the smoke, my friend who was driving behind me did.
3. my dash board is like a christmas tree. when I start the car the airbag starts falshing and stays like this. when I start driving the car the VDC and SLIP lights come on.
what could cause the problems above?
Old Jan 14, 2007 | 09:28 AM
Madelinot's Avatar
Madelinot
1. You have air trapped in the coolant system.
2. Not sure.
3. Too much power? Spinning?
Old Jan 14, 2007 | 09:46 AM
failsafe306's Avatar
failsafe306
Sounds like a bad install to me.
1. They need to bleed all the air out of the cooling system.
2. They overfilled the oil.
3. They didn't align the steering column correctly.
Did they read the instructions at ALL?
Old Jan 14, 2007 | 09:52 AM
Madelinot's Avatar
Madelinot
That makes sense. I didn't think it was a new install.
Old Jan 14, 2007 | 11:39 AM
phunk's Avatar
phunk
CJ Motorsports
I agree with above posts.
1. Air in cooling system or worst case is blown headgaskets.
2. Possibly burning some oil. The APS kit is sensitive to that.
3. Steering column u-joint wasnt put on right.
Old Jan 14, 2007 | 11:42 AM
LvntheZ's Avatar
LvntheZ
damn you guys are good!
Old Jan 14, 2007 | 12:00 PM
maximumsportZ's Avatar
maximumsportZ
+1 sounds exact.
Old Jan 14, 2007 | 12:44 PM
Julian@MRC's Avatar
Julian@MRC
+2 On the above
Old Jan 14, 2007 | 01:05 PM
Sean's Avatar
Sean
Originally Posted by MRC Motorsports
+2 On the above
offer to fly out and help him if he pays the air fare.
Old Jan 14, 2007 | 06:48 PM
blackend's Avatar
blackend
same as what you said bad install and i think they didnt read manual
Old Jan 15, 2007 | 12:40 AM
gecof1's Avatar
gecof1
Newbie
In addition to that, the flashing of A/B is due to a bad installation of the A/B sensor. Check for loose wiring. Flashing is the symptom that the sensor is not active
For anything else I fully agree with the previous post
Old Jan 15, 2007 | 03:21 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
sounds like a blown headgasket on the coolant being over flowed. we werent sure at first either until i noticed water in the oil...
change your oil immediately and see if there is ANY milky white looking sludge in the oil, if so, dont drive the car at all cause you could possibly destroy some bearings inside the engine
Old Jan 15, 2007 | 09:52 AM
Nismo350ZRT's Avatar
Nismo350ZRT
+1. I hope this wasn't installed by a professional shop.
Old Jan 15, 2007 | 04:58 PM
priscilla ls1's Avatar
priscilla ls1
I remember reading that is was professionaly installed here is the thread.
https://my350z.com/forum/forced-induction/236767-its-officially-at-the-shop-aps-tt-install.html
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
