Any Twin Turbo for the 2006 350Z
Old Feb 20, 2007 | 09:11 AM
Abishop's Avatar
Abishop
sorry if I'm reviving an old thread, but will some one clear up all the Turbo, Twin Turbo, Supercharger Kits out for the Rev-up engine. Thanks.
Old Feb 20, 2007 | 05:46 PM
Abishop's Avatar
Abishop
Anyone?
Old Feb 20, 2007 | 06:29 PM
Julian@MRC's Avatar
Julian@MRC
Originally Posted by Sharif@Forged
the kits fit on the 06...motor mount needs to be shimed about 3/16th of an inch.
Shiming the motor is not advisable..Your changing the angle of the motor to tranny and the entire drive line.Even so slightly, if its off enough, you could run into issues with the crank and main bearings..If you shim the motor up, you need to shim the tranny up also to let the "U" joints on the Drive shaft make up for the 3/16" in stead of putting the exess strain directly on the crank shaft and input shaft.
Shaving the knuckle, following the install instructions for the APS extreme kit and you will be fine..
Old Feb 21, 2007 | 05:16 AM
98sr20ve's Avatar
98sr20ve
How does shimming a motor mount (which is what I assume they are talking about) change anything as far as the "Motor to tranny". They are solidly bolted together. It would change the angle of the transmission to driveshaft of course.
Old Feb 21, 2007 | 08:02 AM
Julian@MRC's Avatar
Julian@MRC
By raising the motor 3/16" of an inch and leaving the tranny at the same level without shimming it, you could put extra strain on the tranny input shaft to crank shaft, regardless of the bolting of the tranny. Idealy, you want every component from the crank shaft to tranny to rear end on a level plane..Im sure someone will debate my explenation with some long winded cut and paste on something they read somewhere..But this is basic stuff, I may not be doing a good job explaining it..But most people understand what I am reffering to, as far as keeping the engine and transmission as true as possible since it is a rotating mass.
Old Feb 21, 2007 | 08:28 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
This is not correct. The only "strain"...if you want to call it that, is the driveshaft connection to the trans. The trans and engine are fixed, and that angle does not change. With a universal joint in that location, and the constant flexing of the chassis, it is unlikely you will harm the driveshaft, or the output shaft.
Either way, we can mod the steering knuckle on the 06's in order to make it fit without shimming.
Old Feb 21, 2007 | 08:42 AM
chris'smax's Avatar
chris'smax
can anyone verify if the greddy kit fitts the 06 rev-up? I will be purchasing this kit very soon and don't want to get in there elbow deep and find all kind of fittment issues
Old Feb 21, 2007 | 09:43 AM
Sharif@Forged
Forged Performance
It fits...no issues.
Old Feb 21, 2007 | 10:32 AM
Julian@MRC's Avatar
Julian@MRC
You could nt be more wrong if you tried..But I will allow you to gloat and think your correct..Good luck with that one, would love to see his main bearings after 25,000 miles.
Old Feb 21, 2007 | 11:58 AM
Sharif@Forged
Forged Performance
Not gloating...just correcting the incorrect info you posted. Have a nice day.
And either way, we havent shimmed an APS TT kit 06 engine, merely pointing out that it can be done.
Old Feb 21, 2007 | 12:47 PM
Julian@MRC's Avatar
Julian@MRC
Ill let you think you correct... but your not..
Old Feb 21, 2007 | 01:06 PM
Abishop's Avatar
Abishop
I'm sorry but will some one please tell me where i can find or will some one tell me all the twin turbo, single turbo, supercharger kits that fit on an 35th/06 rev-up without modifying the steering?
Old Feb 21, 2007 | 01:35 PM
chris'smax's Avatar
chris'smax
Thanks buddy, your a gent and a scholar
Old Feb 21, 2007 | 01:42 PM
zman1910's Avatar
zman1910
Did you read the thread? It addresses your question
Kits that will fit include
TT - JWT, Greddy, and APS(with minor modification)
ST - APS, TN - both require modifications
Superchargers - Vortech and Stillen I believe
Your best bet would be a TT or supercharger kit. I would avoid the ST's for now...
Old Feb 21, 2007 | 01:48 PM
Abishop's Avatar
Abishop
I did, but i wasn't clear. thanks for the info, one last question.
Your saying JWT and Greddy will fit with no modification on ANY parts?
Old Feb 21, 2007 | 01:56 PM
CESAROTORRES's Avatar
CESAROTORRES
Default Kits That Fit The 06
You forgot the POWER ENTERPRISE TT.
CESAR
Old Feb 21, 2007 | 02:00 PM
Sharif@Forged
Forged Performance
That is correct.
Old Feb 21, 2007 | 03:40 PM
  #38
Julian@MRC's Avatar
Julian@MRC
CESAR
Not very popular for some reason.. Also look into the SFR turbo kit..This is the one the big dogs need to sport.
Old Mar 28, 2007 | 03:22 PM
  #39
Abishop's Avatar
Abishop
what modifications do you have to do to the steering knuckle on a revup to install the aps tt kit?
Old Mar 28, 2007 | 04:44 PM
  #40
Nismo350ZRT's Avatar
Nismo350ZRT
Wait a minute...you have a 35th Aniv? You don't need to mod the knuckle on 03-05's...just grind it down a little. The 06's need the knuckle mod because the steering rack is different than 03-05's, not because of the revup motor.
