oil in spark plug access
Old Jan 19, 2007 | 04:03 PM
Sisith's Avatar
Sisith
Default oil in spark plug access
Hey guys im installing my vortech right now but ran into a snag. I have changed out some of the spark plugs and when I pull out the coilpacks everything was normal until I got to one that was dripping oil. It is the same color as my dirty engine oil and there is alot of it. Im hoping its nothing serious but this has me very worried. I also noticed there is alot of oil in the upper and lower plenum runners. The one that is full of oil is the one closest to the driver. Please help me fix this!
Old Jan 19, 2007 | 04:16 PM
GurgenPB's Avatar
GurgenPB
UltimateSleeper
Your valve cover seals are licking...need new va;vecovers, they are ~$200 each, but dont quote me on that
Old Jan 20, 2007 | 05:01 AM
Kenk2's Avatar
Kenk2
Professional
Anyone else have any input on this?? Gonna try to fix this today, install the vortech and tune tomorrow.. Would like to have this resolved asap. Thanks for the help peeps!
Ken
Old Jan 20, 2007 | 01:22 PM
GTM's Avatar
GTM
Vendor - Former Vendor
+1 Gurgen is correct, I had this issue on my car and it was the valve covers. Seems to be a common problem for some reason.
-George
GT Motorsports
Old Jan 20, 2007 | 01:42 PM
GurgenPB's Avatar
GurgenPB
UltimateSleeper
Yep and I learned that from george's car.
Old Jan 20, 2007 | 04:19 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
we have spare valve covers... i'll see if i can find a good looking one for you...
pm me
Old Jan 20, 2007 | 04:20 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
Ken
the spark plug cylinders are sealed to the valve cover with a circular compression spring...when these lose their tension/or stretch, the seal is compromised and oil leaks over from the valve cover into the spark plug tube...
no real way to change the spring seal, only the entire cover
Old Jan 21, 2007 | 07:14 AM
Kenk2's Avatar
Kenk2
Professional
Busted open the motor yesterday, early.. Set us back a few hours from installing the Vortech and bustin a bolt didnt help us much either..
Not 1 dealership had a valve cover bolt in stock so Seans dad drove to a little town outside Tucson called Sierra Vista.. about a 3.5 hour drive total and picked up a bolt + an extra just in case.. Dude Sean, you need to do major housework or makin dinner for Pops or somthin cause I was ready to roll to Sierra Vista..
Anyways, the valve cover had 1 bolt that was just loose.. It was the driver side valve cover, all the way back.. It is a pita to get a ratchet too so I just put the extension on it by hand, and started turning it with my fingers.. We are hoping that was the problem..
We took the valve cover completely off, cleaned everything up and put it back on.. Hopefully that works.. If not, Todd, I will have Sean hit you up for a new one..
I do appreciate the offer Thanks very much to whoever posted in this thread. 2 total Newbs breakin into this motor and 3-4 peeps giving out alot of help.. Appreciate it again..
Ken
Old Jan 22, 2007 | 07:37 AM
350zDCalb's Avatar
350zDCalb
builtZmotors
a few of the valve cover bolts are a PITA to access with the motor in the car, for sure..but nothing that a swivel socket 10mm on an extension can't get to.
Old Jan 22, 2007 | 12:52 PM
Eazzy's Avatar
Eazzy
And 1/4 inch drive helps
Old Jan 22, 2007 | 03:32 PM
Audible Mayhem's Avatar
Audible Mayhem
My350z
And beer helps..
Old Aug 5, 2007 | 09:22 PM
roneski's Avatar
roneski
Just ran into the same thing on the #6 cylinder while changing my plugs today.
Old Aug 6, 2007 | 08:28 AM
QuadCam's Avatar
QuadCam
changing the valve covers in the car isn't easy, but it is more than doable. I justt didi it last week, when I painted my valve covers. trying to put the new covers on without messing up the paint is gonna be harder than just manhandling the covers back in there.
those gaskets suck though! mine kept falling off right before I have the covers in place.
Old Aug 6, 2007 | 02:09 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
the trick is puuting a dab of rtv on the surface of the gasket that fits inside the groove in the valve cover, at each corner, this will keep it in place long enough to wrestle it back onto the cylinder head
Old Aug 6, 2007 | 02:23 PM
Eazzy's Avatar
Eazzy
That works well---also what works is a spray gasket locator sold by Napa ---But what I have also used is the spray Battery terminal protector and the spray Brake anti-squeal---They really all seem to be the same product with a different name. I spray the valve cover side---let it tack---position it and lay the valve cover on a flat surface weighted down with a couple LBs and walk away for 30 minutes and prep the surface of the block or whatever
burglapfd
Dec 6, 2020 01:04 PM
350z82
Oct 1, 2015 06:25 PM
