compression testing on 350zT
Old Jan 25, 2007 | 07:45 AM
ryan350zpower's Avatar
ryan350zpower
Default compression testing on 350zT
well, ive had my Z with my turbonetics kit on now for over 25k miles and i thought i would get a compresison/leak down test. To sum it real quick, 2 out of the 6 cyclinders had a 3% difference (2 had 7% and 4 had 10%). And all the leaks were pass the rings. just checking with you guys to compare numbers on your turbo Z's. thanks
Old Jan 25, 2007 | 08:05 AM
Alberto's Avatar
Alberto
Cranky FI Owner
My stock motor was 185-195 across the board IIRC...
Old Jan 25, 2007 | 04:08 PM
Eazzy's Avatar
Eazzy
I could run a chk out of curiousity but what ur running is fine and Alberto, if ur running 185-95 on compression ur doing Great, They should stay withing 10 or so % ideally
Old Jan 27, 2007 | 11:27 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Are you talking about a leakdown percentage? If so, I would be concerned with anything near 10% or more leakdown. Most factory engines will leak down at less than 3% across the board.
Old Jan 27, 2007 | 01:47 PM
ryan350zpower
sharif, you mean 10% between cylinder difference? some of my cyliners were at 3% and some hit 10%
Old Jan 27, 2007 | 02:02 PM
Sharif@Forged
Forged Performance
With a basic compression check, you look for consistency between the cylinders, and hopefully you see less than 12-15psi variations between the holes.
But for a leakdown test, we dont compare...we look at the leakdown percentage individually. Anything more than 10% is concerning, as stock engines usually likedown at about 1-3%. They are very tight.
For instance..if you had 2%, 2%, 3%, 3%, 1%, 11%, this would indicate an issue with the last cylinder. The difference between cylinders, in this case, is irrelevant.
a 10% leakdown isnt the end of the world, it just means that cylinder is a little bit tired, and you might want to start saving up for an engine build.
Old Jan 27, 2007 | 02:03 PM
Eazzy's Avatar
Eazzy
10 % on compression not leakdown ---I really dont know what +- it should be ----U say 3 % Sharif ?
Old Jan 27, 2007 | 02:04 PM
Eazzy's Avatar
Eazzy
U were typing the same time I was ---Thanks, thats what I was asking
issyz
Jul 2, 2017 03:04 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
codek
Sep 28, 2015 03:03 AM
