SGP: 653RWHP & 598 pump gas!
Originally Posted by Nismo350ZRT
Wow...incredible numbers!!
You made that much power on a single 3" exhaust? Man, if that's true, the argument that you need dual 3" exhaust just went out the window.
I would like to see a dyno from another shop one of these days or the dyno sheet.. Far as I knew the 18G's fall on there faces about 18+PSI.
I just saw 18PSI above. Interesting.
Today is the 25th, I just got the email today from Mark about the power #'s
No race gas involved what so ever, stock turbo's. Picking up the car this weekend and will have dyno charts then. I'm not sure what type of dyno they have but I do know it's the one that you attach to the wheel hubs where you have to take off the wheels
What fuel system are you running? I didnt think a single Walbro would safely hold much past 600whp...congrats!
edit-I think SGP runs a dynapack? If so that would explain it. Not downplaying your numbers just would explain this better, regardless the car is nasty fast be careful out there!!
The Walbro holds up fine to around 600 depending on injectors
The heads with SGP custom port/polish with cams made a HUGE difference because before I had all that work done I was running stock heads and had a little over 525rwhp around 16psi with a UTEC but have since switch the V-Pro
Yep, heads make a massive difference. Especially with the +1 oversize valves and the cams...
Nice work with the un-sleeved block. I'm glad that somebody's pushing the short block to see if the sleeves and half inch headstuds are really "required" to hit 600whp...
Originally Posted by Old School
its a dynapack dyno guys...and set-up correctly...reads lower than a dynojet... no overzealous dynos at SGP...trust me.
Most of us know this.. I found it odd that Alberto made that comment as well.
Originally Posted by sentry65
well we've all seen some dyna-pak dynos that read about 50-60whp higher than dynojets. They're kinda all over the place
Either way - congrats!
