Professional analysis and pictures of our 6MT internals
Old Feb 18, 2009 | 09:56 AM
  #221
ttg35fort's Avatar
ttg35fort
Professional
Originally Posted by BriGuyMax
Do you know if they use the stock synchro setup or their own proprietary synchro setup?
They make the synchro's, but I'm not sure how they differ from the stock ones other than everything is supposed to be significantly stronger. Give Sam a call (late in the even our time is morning their time). I'm sure he will answer any questions that you have. He answered all of mine.
If you want his e-mail address, PM me and I'll send it to you. Otherwise, you can just send an e-mail their wb contact form on their website (like I originally did), and it will be forwarded to somebody technical who can help you, maybe even Sam.
Old Feb 18, 2009 | 10:25 AM
  #222
BlinkerFluid's Avatar
BlinkerFluid
Originally Posted by 350Zenophile
haha...you sure about that? ***** deafening...
That seems to be an all out race car, the only interior it probably has is the dash. My straigt cut box isn't near that loud in my other car. It's bearable. The fact that it's under the hood and not between the seats probably helps too.
Dog engagment works just fine on the street so long as you put the shifter where it belongs with authority and don't limp wrist it.
I'll see if I can find a video of mine.
Old Feb 18, 2009 | 09:36 PM
  #223
Nealoc187's Avatar
Nealoc187
My straight cut gears aren't unbearable either, but it would suck if I had a straight cut 5th gear, that would get annoying really quickly on the highway. Definitely glad I still have a stock 5th gear.
Old Mar 19, 2009 | 02:10 PM
  #224
SIR_pierre's Avatar
SIR_pierre
i dont know it this ie the right thread...but
with oil should we use.. i always drive mine hard and do many track days. when mine broke i had the redline shockproof something.
Old Mar 19, 2009 | 02:41 PM
  #225
betamotorsports's Avatar
betamotorsports
redline shockproof
Shcokproof is not really appropriate for transmission with synchros (if that's what yours has). Its designed more for racing transmission running dog engagement.
Old Mar 19, 2009 | 03:01 PM
  #226
SIR_pierre's Avatar
SIR_pierre
yes i had and sorry to say will have an OEM tranny
Old Mar 19, 2009 | 08:48 PM
  #227
Nealoc187's Avatar
Nealoc187
yeah you don't want to run shockproof.
Old Mar 20, 2009 | 02:49 AM
  #228
SIR_pierre's Avatar
SIR_pierre
yeah i understand that now...so what should i use??
Old Mar 20, 2009 | 09:59 AM
  #229
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Redline MT-90 or AMSOIL MTG are probably the best options
just make sure whatever you put in is GL-4 and 75w-90
Old Mar 20, 2009 | 10:09 AM
  #230
SIR_pierre's Avatar
SIR_pierre
but that was the one i had! MT-90 GL4... i wa sure it was called shockproof aswell...guess i was wrong about that
i think it said on their site that it was for nisssan cars..
http://www.redlineoil.com/products_g...7&categoryID=7
Old Mar 20, 2009 | 10:39 AM
  #231
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Then you had the right one. MT-90 is not one of redline's "shockproof" gear oils.
The shockproofs are listed here:
http://www.redlineoil.com/products_g...bCategoryID=16
Old Mar 20, 2009 | 10:47 AM
  #232
SIR_pierre's Avatar
SIR_pierre
so i can use that one again when i get my tranny fixed?
Old Mar 20, 2009 | 10:53 AM
  #233
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
definitely...that's what I use...
Old Mar 20, 2009 | 10:56 AM
  #234
SIR_pierre's Avatar
SIR_pierre
ok.. for from what i can understand from the secretary at the workshop i hade same problems as everybody else. 3rd gear splitt in two and ALL the synchros was damaged
Old Mar 20, 2009 | 02:25 PM
  #235
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Synchro damage doesn't usually happen with that type of failure. My trans failed the same way and my synchros are perfect.
Old Mar 20, 2009 | 02:29 PM
  #236
SIR_pierre's Avatar
SIR_pierre
i think the syncro problem is becuse of my JWT clutch/flywheel..
i dont see any way to adjust the clutch.. but i think ever since i installed them and changed the oil ( did it at the same time) the gears grinded alot more!
Old Mar 20, 2009 | 03:19 PM
  #237
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
You need to adjust the clutch pedal, the clutch probably isn't disengaging completely on shifts thus the grinding.
Old Mar 20, 2009 | 03:21 PM
  #238
SIR_pierre's Avatar
SIR_pierre
yes thats sounds correct to me to but i dont find any way to adjust it!
Old Mar 20, 2009 | 07:48 PM
  #239
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
under the dash where the clutch master cylinder arm comes through the firewall, there is an adjustment.
Old Mar 21, 2009 | 12:04 AM
  #240
rrmedicx's Avatar
rrmedicx
What about the pivot ball? Could that also be a potential culprit for his clutch not disengaging? They do sell a stronger pivot ball appropriate in size for which ever year transmission you may have swapped over to. I think the change in size of pivot ball occurred from '05 to '06 but I could be wrong. So be careful if you swapped from an '05 or older tranny to a newer '06 or newer just make sure you are using the correct pivot ball.
Just a thought.
