View Poll Results: stock motor?
yes
69
64.49%
no
38
35.51%
Voters: 107. You may not vote on this poll
turbonetics st owners
Old Feb 2, 2007 | 05:12 PM
  #41
zectasy's Avatar
zectasy
Originally Posted by MIAPLAYA
By ECU do you mean piggyback, stand alone?
doesnt matter. whatever would be the best to run with the kit.
Old Feb 2, 2007 | 05:19 PM
  #42
MIAPLAYA's Avatar
MIAPLAYA
In the end it depends on your budget. Of course any stand alone is going to be better then a piggyback. Personally an HKS Fcon V Pro or Haltech would be the best all around.. but a UTEC will do.
Old Feb 2, 2007 | 07:05 PM
  #43
JETPILOT's Avatar
JETPILOT
Technically a UTEC is not a piggyback ECU. It's a parallel ECU. Greddy E-Manage Blue and Ultimate are piggyback ECU's.
JET
Old Feb 3, 2007 | 07:06 AM
  #44
MIAPLAYA's Avatar
MIAPLAYA
JET
I never said it was a piggyback. I said stand alones are better then piggybacks. Then I listed the top 3 stand alone units including the UTEC..
Old Feb 5, 2007 | 12:44 PM
  #45
VIZAGE's Avatar
VIZAGE
Originally Posted by VIZAGE
Outside of warrenty, what does Turbonetics charge for replacing oil seals? For I see this will be necessary through out the years to come. I'll call it regular maintenace.
Miaplaya did you every check into this for? It would be well apperciated. Thanks.
Old Feb 5, 2007 | 02:11 PM
  #46
MIAPLAYA's Avatar
MIAPLAYA
Labor is $290 for a basic overhaul/rebuild. Add to that the parts cost of $150-250 for seals, bearings if needed, other bad parts. Typically $400-500 based on something being broken aside from the seals... Thats the info I got from Turbonetics. This is for the ceramic ball bearing unit of course...
Old Feb 5, 2007 | 05:49 PM
  #47
JETPILOT's Avatar
JETPILOT
Yeah... and like I said previously. The UTEC is not a standalone unit and it's not a piggyback. It's a parallel ECU.
JET
Old Feb 5, 2007 | 05:55 PM
  #48
Alberto's Avatar
Alberto
Cranky FI Owner
I am one of the best and worst examples of a TN set-up on a stock motor. TN kit, UTEC, AAM Stage1 fuel system, good tune, HKS DLI ignition, it lasted 3000 miles before it sent 2 rods through the block. Hard to say for sure, but from talking to knowledgable people/shop owners and seeing how many motors are staying alive now-a-days as compared to only 1 year ago it was likely my raised limiter and my abusive racing habits (up to 7100rpms from6600). Good luck with it, the kit on a stock motor is great
  #49
MIAPLAYA's Avatar
MIAPLAYA
JET
If I was going to describe the operation of the UTEC and put it in one of the two categories I would say stand alone is it actually initiates timing and fuel adjustments rather then just modifying the stock output signal. That being said I put it in the standalone category when I talk about it. But tomato, tamato..
Old Feb 5, 2007 | 06:25 PM
  #50
IIQuickSilverII's Avatar
IIQuickSilverII
......But tomato, tamato..
Old Feb 6, 2007 | 09:08 AM
  #51
QuadCam's Avatar
QuadCam
these poll results are BS.....
most people have the TN kit on a stock block. The poll is showing 36 people with this kit on a built motor......I can only think of 3 or 4 people using this kit on a built motor
Jambo016
Sep 16, 2016 01:08 PM
kyin
Oct 15, 2015 05:54 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
Tochigi_236
Sep 27, 2015 03:40 PM
