UTEC and 550cc injectors or bigger , problem...
Old Feb 7, 2007 | 05:53 AM
al v's Avatar
al v
Default UTEC and 550cc injectors or bigger , problem...
There is any way to solve the warm starts ,with 550cc injectors or bigger, with the UTEC ?????? I know that pushing the gas pedal ,you could get easy starts , but even with this , sometimes my car takes a very long time to start, and the dark smoke after that is killing me.......
Old Feb 7, 2007 | 06:02 AM
ZU L8R's Avatar
ZU L8R
Viper Sellout
I don't have any problems and I'm running 650's
Old Feb 7, 2007 | 06:15 AM
al v's Avatar
al v
Lucky you........I have the problem only when the engine is hot , I don´t have the problem after around 1 hour....
Old Feb 7, 2007 | 07:05 AM
Dirty Dave's Avatar
Dirty Dave
Same here, if the motor is cold it fires right up , but when warm its ral stubburn to start, interested to see if there is a solution.
Old Feb 7, 2007 | 07:28 AM
lemansz20's Avatar
lemansz20
I was confused on what you were talking about, but crap I would LOVE to see how people solve this one b/c I have that same problem tooo. I have to say that I feel alot better lol that my car is not the only one that does it lol.
Old Feb 7, 2007 | 08:43 AM
QuadCam's Avatar
QuadCam
I fuel return setup makes warm starts a breeze again due to the lowering of the fuel pressure (by the FPR) as the engine pulls vaccum. my car starts right up with 550s and a fuel return. before the fuel return, warm starts took a little time.
Old Feb 7, 2007 | 09:02 AM
KPierson's Avatar
KPierson
What kind of fuel pressure are you running?
I've got a UTEC, 650cc injectors, a Walbro 255, and a complete fuel return system. I'm running a base pressure of 50psi and the car starts right up with no problems.
I used to run a base pressure of 60 and the car wouldn't always start when warm. Ever since lowering the pressure it's made a big difference.
Old Feb 7, 2007 | 12:23 PM
Tuning Factory's Avatar
Tuning Factory
if you could get ahold of a code scanner that can read short value fuel trims, it may allow you to dial it accordingly. it may be the fuel at idle and just off idle is out of whack a bit.
Old Feb 7, 2007 | 12:25 PM
redman333's Avatar
redman333
I have the same issue, my car starts hard but I don't get smoke though.
Old Feb 7, 2007 | 02:32 PM
Alberto's Avatar
Alberto
Cranky FI Owner
You can trim it out a bit in the fuel table to help some. I run 750c's and its tricky to get used to starting warm, but I can get it with good timing of cranking and throttle modulation every time
Old Feb 7, 2007 | 03:17 PM
AmateuRN's Avatar
AmateuRN
I have 750's, UTEC, and SGP return fuel syst. and I have hard warm starts also... I hate it, I'll let the car idle for 20min rather then shut it off and have to start it again, lol.
Subscribing...
Old Feb 7, 2007 | 03:34 PM
al v's Avatar
al v
I have the APS fuel regulator ( 3.5 bar ) with a custom made complete fuel return ( cjm fuel feed , stock modified fuel rails , and the aps FPR )
Old Feb 7, 2007 | 03:42 PM
al v's Avatar
al v
I have a -20 in the 500rpm, and a -15 in the rest of the 0% column , but this isn´t help too much..........
Old May 24, 2007 | 03:53 PM
kevin8086's Avatar
kevin8086
anyone ever figure this out because my car does the same thing??
Old May 24, 2007 | 04:17 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Seems like every car, and every injector, can be hit or miss. We've done a bunch that crank right up when warm, and a small minority of others, need a throttle blip. Lowering the pressure to 37-42psi can help, but then you sometimes run out of fuel up top, depending on the injector size the customer has.
With the FCON, all of our cars start right up...instantly...with no throttle intervention. The low impendence injectors we use with the FCON, have far superior response time, when compared to high impedence injector. So they operate much better at low pulseswidths, such as start and idle conditions.
Hope that helps.
Old May 24, 2007 | 04:21 PM
paranormal's Avatar
paranormal
Evil Boy 4 LIFE
I so wish i got a freakin FCON from the Get go!!!!!!!!!!!!!
Old May 24, 2007 | 04:28 PM
Sharif@Forged
Forged Performance
Arent you getting one now from Sam@GTM?
Old May 24, 2007 | 04:29 PM
diwun67's Avatar
diwun67
Hehe even with the 380cc injectors I have, the car starts kinda soft I guess you could say, when it's warm
Old May 24, 2007 | 04:36 PM
paranormal's Avatar
paranormal
Evil Boy 4 LIFE
Yeah i am but i wish i would have dont alot of things differently from the get go.. like sending you my car the first time when i was on the east coast....
the more i read about the HKS the more im satisfied with this purchase..
Old May 24, 2007 | 05:05 PM
sentry65's Avatar
sentry65
the burninator
you'll be happy with the Fcon. I wish I went with it sooner too
