More ATS Clutch Problems
Old Mar 29, 2007 | 02:47 PM
  #61
redline350ZZ's Avatar
redline350ZZ
Originally Posted by JonathanG35
- did you take any pics of the install?
No I didn't because for me it was such a pain
- how long did it take?
If you do not run into complications I would imagine it taking 2 hours max
- did you replace your clutch fluid with something like motul?
I was unable to get special fluid in Hawaii so I used a valvoline 500 degree fluid, I may get Motul when I order something else from the mainland
- need any special tools other than the flare nut wrench?
Um well Flare 10mm for sure, the Slave cylinder bolt was a 12mm and the bleed line was 8mm. Get a old coke bottle and some clear vacuum line to put over the bleed line. Drill a hole in the bottle cap and run the line through it that way when you bleed the clutch you can see the air bubbles and once some fluid gets in the bottle air will not be able to return to the slave cylinder when you pump the clutch
Pumping the clutch is a pain. I had a hard time doing and ended up calling help.
Good Luck
Old Mar 29, 2007 | 03:57 PM
  #62
JonathanG35's Avatar
JonathanG35
rock and roll. I really hope this helps. I just cant see it making such a dramatic improvement. Maybe thats why i am in IT and not a mechanic.
Old Mar 29, 2007 | 04:26 PM
  #63
mrtomcat's Avatar
mrtomcat
Originally Posted by captj3
What problems are you having with the ABS system?
from what I was told as solenoid valve blew out and it's a whole unit that needs replacing
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
