greddy Tt KIT????
Old Mar 3, 2007 | 08:06 AM
lemansz20's Avatar
lemansz20
Default greddy Tt KIT????
hey guys, Im thinking of purchasing and used greddy tt kit. Is their any difference from the greddy kits when they first came out to the ones that they are making now??? Also I have a built motor, and used to have tn single, How much psi does it take on the greddy twins to make around 500 whp??? Im just asking b/c I am going to have low boost and high boost, and I would like to have a guesstimation in mind. Thanx guys for all your help.
Old Mar 3, 2007 | 08:32 AM
Julian@MRC's Avatar
Julian@MRC
The newer Greddy kits now have Cast maifolds and WG piping and a cast large oil pan.The old ones do not..I have 2 new ones in stock, best pricing around.PM me if you wish to purchase one..
Old Mar 3, 2007 | 10:47 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
The manifolds are the same, between kits, but as MRC mentioned, the very very early kits had tubular crappy welded downpipes, that looked like a 3rd grader welded t hem. All the later kits have one piece cast downpipes.
We also have a couple kits in stock, and will beat MRC's price by $1....just kidding!
Old Mar 3, 2007 | 10:59 AM
Julian@MRC's Avatar
Julian@MRC
Ill beat your by $1.50
Old Mar 3, 2007 | 12:45 PM
GQ 350z's Avatar
GQ 350z
Lmao
Old Mar 3, 2007 | 12:49 PM
azula's Avatar
azula
lol....iight yall keep going back and forth at the kit will be at $500 bucks.
Old Mar 3, 2007 | 12:50 PM
azula's Avatar
azula
how much are you puttin down with ur tn setup?
Old Mar 3, 2007 | 12:53 PM
Juztin's Avatar
Juztin
I've got the old school kit, no issues here. Pushed the motor into the 5's with 11.6# WG springs and stock compression. With lower compression, probably around 12-13# should get you in the 5's. But depends a lot on tune, exhaust, cams, etc..
Old Mar 3, 2007 | 01:43 PM
lemansz20's Avatar
lemansz20
Yea of course of course, I just the only thing I worry about is the turbos, I really dont want to have to take them out you know. What if any is a common problem with these turbos????
Old Mar 3, 2007 | 02:50 PM
Sharif@Forged
Forged Performance
That is a risk you take with buying used, but you are probably going to save a lot of money on the kit. The question that you have to ask, is whether the cost savings, offsets the risk of a damaged turbo, or missing parts.
When the turbos fail, they usually smoke and burn oil, and will require a $700 rebuild per turbo. So just keep that in mind when you are negotiating the price of your used kit.
Old Mar 3, 2007 | 03:19 PM
lemansz20's Avatar
lemansz20
cool thanx sharif, you are the man, I sent you a pm, on pricing for a new kit, give me a heads up on what you can do on pricing.
Old Mar 3, 2007 | 06:26 PM
Ed 718's Avatar
Ed 718
BRAVEHEART
Shariff is correct you never know the conditions of the seals and or the internal ( Center Section ) of the turbo. The rebuilds are expensive and sometimes even end up being more than buying a new turbo.
Old Mar 4, 2007 | 04:58 PM
IslandZavage's Avatar
IslandZavage
Is it a good idea to purchase the AAM oil pan spacer and AAM oil return lines with the Greddy kit? any comments on the APS oil pan with this kit?
Old Mar 4, 2007 | 05:04 PM
Sharif@Forged
Forged Performance
Very good idea. Also, we offer our FP Spec Greddy oil FEED line kit. The stock Greddy oil lines are poorly made, stiff, they crack, and they will leak with time. Save yourself some money and aggrevation by upgrading the feed lines now. $120 for the lines, with all the fittings and adaptors needed.
Old Mar 4, 2007 | 05:06 PM
dozzer1b's Avatar
dozzer1b
built motor......500WHP probably u can obtain that goal on 12PSI, with an awesome tune, get crazy, and go 20PSI on an agressive tune, and these turbos can probably handle 700WHP b4 they blow, also depends on if there 16 or 18G
Old Mar 4, 2007 | 05:13 PM
lemansz20's Avatar
lemansz20
well lol I dont want to push that much power, honestly I want 500 or a little more on high boost if I feel like racing. I dont drag race at the track at all, I am a road course guy all the way, and tt is just better for the track and I will be able to run a low boost setting. My car is getting like a complete new make over, so its gonna be interesting to see the change.
Old Mar 4, 2007 | 05:14 PM
IslandZavage
PM sent...
Old Mar 4, 2007 | 05:18 PM
lemansz20's Avatar
lemansz20
THe lines Im definately going to upgrade, but would it be better to run the Aps oil pan or the greddy oil pan with the aam spacer?????
Old Mar 4, 2007 | 05:39 PM
Dirty Dave's Avatar
Dirty Dave
Almost everyone uses the stock oil pan with the spacer.
Old Mar 4, 2007 | 06:01 PM
Sharif@Forged
Forged Performance
The Greddy oil pan isnt too bad. Just couple it with the AAM spacer and return line kit.
