Em I missing anything, vortech install
Old Mar 9, 2007 | 07:14 AM
MUZZY's Avatar
MUZZY
Originally Posted by Everybodywildou
https://my350z.com/forum/north-east/254154-visionary-styles-nj-ny-meet.html
Thats the link w/ the details. If you're coming up let me know.
sorry man thats northern jersey a little too long of a drive for me + there is another meet at bucks county colage that im commited too witch is closer
Old Mar 9, 2007 | 07:23 AM
jpc350z's Avatar
jpc350z
Originally Posted by MUZZY
thanks for the info... yea im thinking when im at AAM and talk to them if they can give me a resonable price for 440cc injectors and bigger pump install im going to do it and get it over with + its safer
They did mine. However Be advised your fuel pressure will end up like mine which is around 80 psi. I did not know at the time of the mod that TN had included in there installation instructions (pg 13) what you need to do to get it down to around 52psi...They have you drilling a hole in the FPR and phunk also advises to also drill a 070 in hole in the Siphon jet. You may wanna do a search..
Old Mar 9, 2007 | 07:40 AM
MUZZY's Avatar
MUZZY
uhhh... i think im going to use stock pump i read more today and ppl say its fine for 3.12 pully. hey since you went to aam for the tune how much they charged you and what numbers are u seeing?
Old Mar 9, 2007 | 08:50 AM
jpc350z's Avatar
jpc350z
PM me and be more specific..
Old Mar 9, 2007 | 09:12 AM
MUZZY's Avatar
MUZZY
pm sent
Old Mar 9, 2007 | 09:59 AM
RA11325's Avatar
RA11325
+1 on getting it tuned first. The out of the box tune is not made from the 3.12 pulley.
Old Mar 9, 2007 | 10:23 AM
MUZZY's Avatar
MUZZY
yup yup... called AAM today and im sticking with the pump provided but might up to the 440 injectors or 550 + iridium 1 step colder plugs.
Y are 550cc injectors cost less than 440cc? should i get 550cc over 440cc? i have no clue about injector specs.
Old Mar 9, 2007 | 10:41 AM
jpc350z's Avatar
jpc350z
The vortech pump is an auxilliary to the oem and works in conjunction with the FMU. FMU/Aux fuel pump is dependent manifold press. for the FMU and electrical signal from the S.S. box for the pump. The signal from the S.S. box is dependent upon RPM, and Boost.
Good question about the larger inj's. Don't know the effect of large inj's on idle/performance?
Old Mar 9, 2007 | 07:13 PM
Mr_pharmD's Avatar
Mr_pharmD
where do u find 550cc cheaper then 440cc?
Old Mar 14, 2007 | 10:52 AM
MUZZY's Avatar
MUZZY
http://www.alteredatmosphere.com/mm5...y_Code=350Z_FS
350Z_Al
Oct 29, 2020 07:44 PM
